Question about Tomtom One Europe v2 GPS Receiver
Tomtom ho do i install a new battery in the tomtom 1 europe
    Novelist:
  • 158 Answers
You would have to seriously abuse your tomtom for the battery to have failed. More likely something else is wrong . Anyway , ere goes : Take 4 screws out of back of tomtom ( these are star screws so you will need a special tool but sometimes an allen key will fit. ) At the top / side of the tomtom where you can see the join of plastic between back and front. Pull apart with your fingers . Its tricky but keep trying and eventually it will come apart a little. From that you can release it from the bottom connectors by pushing the back downwards a little against the base of the front. A little waddle and it will part. The batter is located in the back panel and is held in place with a sticky pad. The battery wires terminate in a small plug connected to the main board. The Battery should be marked " Edinburgh " and should be rated at 3.7 volts 1100mAh. Once again , its very unlikely there is any fault with the battery , more likely to be the charger or charging circuit inside the tomtom.
Posted on Feb 24, 2008
TomTomv2 Europe "Waiting for valid GPS signal"
go to www.tomtom.com support and connect u r usb cable and update u r gps device with new updated software that should correct the problem
Jun 20, 2009 | Tomtom One Europe v2 GPS Receiver
Down loading Europe on my TomTom 1/3
Yes you can I have europe and canada on mine.
just plug your tomtom into your computer and start tomtom home
On the computer screen for tomtom select ADD MAPS
Here you can select and buy the maps you need.
Once you have confirmed the purchase you will be given instructions on how to download etc
Some maps may take a little time to install to the tomtom itself.
you should also ensure there is enough space on your tomtom
If not you will have to get an SD memory card.
I use a 4gb one that still has lots of room to spare
Jun 07, 2009 | Tomtom ONE 3rd Edition GPS
DOWNLOAD MAPS
Yes, I can...
First, download and install TT Home:
http://www.tomtom.com/support/support.php?ID=3&Language=1
For questions on using HOME, press F1 within TT Home.
If you havent done it yet, make an account for free here:
http://www.tomtom.com/myTomTom/myProfile/index.php
Connect unit to computer, log in with same info from account creation. Then choose to upgrade/buy map from within TT Home software...
Apr 14, 2008 | Tomtom One Europe v2 GPS Receiver
Changing maps already installed
Hi, Answers to your 2 questions 1 and 2 . ...... 1/ go into PREFERENCES , hit right arow key till you see MANAGE MAPS , Tap that MAP icon and in there will be all the maps you have on the SD card. Select the map you require by tapping the screen. ............................................. 2/ YES , backup the SD card to your PC first. ( you should save everything on the card as it is ) Then delete the Europe map off the SD card and replace it with the USA map . You will need the authorisation code for the USA map in order to activate it. When you return you can swap the maps back again.
Mar 15, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom fault
Having upgraded my Tom Tom ONE Europe with the latest application download and the latest Europe Maps, the device will not now switch on using battery power. The battery is fine, but the device will only switch on when power is present at the USB port. As I performed the two upgrades one after the other I do not know which introduced the change (poor practice by me I'm afraid!) No solution as yet.
Mar 08, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom One 3rd edition - no SD slot and not enough memory
You could probably just manually delete the Canada/USA maps from the device, and copy over the europe (or whichever ones you need) to the device.
Just plug it in, and view the memory like a normal usb drive..delete the old, copy over the new.
Don't forget to use tomtom home to backup your gps device to your computer first (thus saving your canada maps for later..)
Afterwards, you would probably have to go into your preferences and choose the europe maps.
Jan 11, 2008 | Tomtom ONE GPS Receiver
Re battery life??
the battery should last 3/4 hours without a charger.
I think tomtom are aware of a ton of units with faulty batteries / poor life span.
arrange for it to be returned asap.
http://www.tomtom.com/support/support.php?ID=2
Dec 04, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom 1 (new edition) map of europe
I think you'll find that you can download it from tomtom home, with full technical help online & on the phone.
I dont advise COPYING it from a friend as you will get a symbol appear on the screen with a tomtom SD card with a large red cross through it, indicating that the tomtom knows its not a genuine copy.
Dec 02, 2007 | Tomtom One Europe v2 GPS Receiver
TomTom One Europe
What is happening is your map updates are being copied onto your memory card without overwriting the old maps hence you are running out of memory.
In the tomtom home browser you should be able to delete your old map before installing the new one. Make sure you have a back up of the map card before you try this though so you can reinstall if something goes wrong.
Also have you replaced the voice prompts on your tomtom? The voice files take up a lot of memory so if you have put new ones one without removing the old ones you will be wasting memory.
There is one window in TThome that lists eveything installed on yuor card so have a good look at this and see what you can get rid of.
Oct 30, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
945 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
