Philips DVDR985 DVD Recorder
Problem for Philips DVDR985 DVD Recorder
DVD caught inside machine
By LLL2 on Feb 15, 2008
My Philips DVD player will not eject the DVD and I don't know how to get it out.
Comments:
Feb 18, 2008
- Last night my husband hit the top of the machine and the DVD door opened and the DVD came out, we think the door was stuck. Thanks for the tip. We are struggling a little with keeping the door closed but he thinks he can solve that.
Same Problem
Oct 21, 2008
-   MY TAPE WAS PUT IN UP SIDE DOWN AND CAN'T OPEN THE DOOR TO FIX THE PROBLEM. IT WON'T EJECT-   maxi4049
Best Solution
posted on Feb 15, 2008
Helpful)
Benimur
Rank: Guru  Philips Expert
Rating: 88%, 3833 votes
Other than opening the unit and manually working the mechanism to extract the disc, the only possible way is to give the unit a solid tap/whack at the top cover central relative to the position of the disc itself. tough this may sound not so technical, this is based on the assumption that somehow the mechanical portion of your unit is defective or simply stuck.
If your concern has not been corrected after completion of the above procedures, then obviously, the unit must be opened up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Comments:
Feb 19, 2008
- Glad to be of assistance and appreciate the rating.
Though I agree with sharcnet in principle, the initial recommendation was based on the presumption that as of the moment, all you need was to remove the stuck disc.
As to be noted, my opening statement was to open the unit (and of course have a look & see). Further I qualified my suggestion as un-technical and hence forwarded it as an immediate but not a long term solution.
Nonetheless, I likewise thank sharcnet for sharing his personal view.
Was this helpful?
Yes
No
Solution #2
Helpful)
sharcnet
Rank: Guru
Rating: 92%, 1144 votes
When a DVD won't eject, the most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the DVD. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) try to find the motor and belt which operates the DVD loading & eject mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the DVD is why you may not have this problem during a load sequence.
Let me know what you find and we'll go from there.
Good luck,
- Jim
Comments:
Feb 18, 2008
- While that might get the disc out on occasion, it's not a practical, guranteed or long-term solution, especially if its mounted in an entertainment rack. I would also worry about long-term effects on the mechanics with continued "whacks".
The proper long-term solution is to find out what's causing the problem. If it happened once, it will most likely happen again.
I wouldn't want to own something where I'd have to keep hitting it to make it work.
- Jim
Was this helpful?
Yes
No
Popular Solutions for Philips DVDR985 DVD Recorder
Questions and Unsolved Problems for Philips DVDR985 DVD Recorder
Do you recommend Philips DVDR985 DVD Recorder?
Answer
Answer
The tv picture from the monitor setting through the Philips DVDR985 DVD Recorder is bad. What do I... (More)
Answer
I was able to record when I had DirectTv, but now have Mediacom cable and no luck - just wondered if... (More)
Answer
how do i "lock in" or render my disck so i can play it in other devices
Answer
I have a DVD stuck in the player after it crashed and reset itself, unfortunately the remote has... (More)
Answer
how can I get a users manual for a philips DVDR985/171 ?
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
