Door not closing Zanussi FX1265W 1200 Auacycle
Press button to start wash and hear 2 clicks from door interlock. machine then beeps 4 times and flashes 4 times. Manual says door not closed. I have fitted a new door interlock but still get the same problem. Any ideas?
  • Anonymous Aug 20, 2008
    Same problem. Changed doorlock with no result. Must be main PCB.
    Solution: I've ordred a new Bosch!!!
    Mark Allinson
  • boro09 Jan 22, 2009
    Hi
    I have the same problem ! where do i locate the triac (BTB16) on my Zanussi FX1465W
    Ray
Further to my previous posting, I have now got a new Bosch but I have removed the PCB from the FX1265W. I found that the printed circuit track between the edge connector and the triac has blown. The triac (BTB16) was tested and faulty. New triac is on order (£1.03). I will post again when it has been fitted and the track is repaired and if the machine works.
Mark Allinson
Posted on Aug 22, 2008
  • skipper70 Aug 28, 2008
    Zanussi FX1265W
    Further to my post 22nd Aug, I replaced the triac and repaired the track on the main PCB. The triac actually tested OK with no shorts or any sign of damage but I fitted a new one. New door lock assembly was fitted. Washer was re-assembled and now works perfectly. New triac £1.13, new door lock £25.
    Skipper70
  • 54 Answers
You need a new main pcb. this is a common fault
Posted on Feb 15, 2008
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Jun 07, 2015 | Zanussi Washing Machines
I NEED A USER MANUAL FOR MY ZANUSSI AQUACYCLE 1200 XC6 WASHING MACHINE FX1265W TO ENABLE ME TO IDENTIFY THE DIFFERENT PROGRAMME SYMBOLS THE PRODUCT NO.IS 91479270300 TYPE F6857648 CAN YOU HELP
You can download a user manual from here:
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/FX1265W-_E
Kind regards,
Ian
Nov 29, 2009 | Zanussi Washing Machines
Zanussi aquacycle 1200 washing machine
The Timer/ECU is likely failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Washing Machines
ZANUSSI ZWF1437W WASHING MACHINE
yes sounds like door interlock cheap and easy diy job goodluck and unplug regards jason
Jun 14, 2008 | Zanussi ZWF1430W Front Load Washer
Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Jun 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FX 1265 W, Aquacycle 1200 Door Problem, won't lock.
take a look at this link.
I have found that a lot of front loaders use the same control board manufacturer with the same solder failure issue.
try the section where you pull up on the white connecter with black wires as it is the easiest to verify the issue
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Feb 02, 2008 | Washing Machines
Fjs1225w machine wont start
If its not the door interlock then the only other possible thing is the control module has failed ....
it does happen on zanussi machine.. is it making a cliicking noise the door interlock.... when you press start .... like click click....
if so then most likely its the control board inside the machine
Jan 20, 2008 | Zanussi FJS1225W Front Load Washer
Door won't open and no error lights
sounds like the door interlock is manfunctioning.
Jan 19, 2008 | Zanussi FJS1225W Front Load Washer
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
216 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
