Once
you have all the wireless settings of the router, you are ready to
connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select
the name (SSID) of your wireless network. If your router isn't
broadcasting your network's name, select Specify Unlisted Network and
enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You
can try to reduce the MTU settings on the router. if the MTU on the
router is set to 1500 then change the MTU to 1365. Also you will need to
open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Once
X-BOX
4. Select
enter the name.
You
Once you have all the wireless
settings of the router, you are ready to connect the play station or the
X-BOX
Open the
Network.
3.
On
4. Select
enter the name.
5.
If
6. Try to
You can
try to reduce the MTU settings on the router. if the MTU on the router
is set to 1500 then change the MTU to 1365. Also you will need to open
For
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
