Question about HP iPAQ HX2490 Pocket PC
New hp ipaq enterprise 210 won't start from mains
Dear Sirs,
I have just stumbled across your site, whilst searching for assistance regarding my current problem with a new ipaq 210 (Enterprise 214 here in the uk).
Please can you help...
The ipaq won't now start from the mains - it will only start using the internal battery, and seems to work normally then. I use a mains charger, that is clearly charging the ipaq ok, as I have tested it going from from 98% to a full charge (orange light turns green on the ipaq). So the cable is fine. It must be something to do with the ipaq itself.
Note that I only recently tested the alarm clock (turning the ipaq on automatically). But I haven't done anything substantial with the ipaq, just tested videos, used an sd card, synched with my PC a few times, and installed calligrapher (I have been mostly writing notes to get it used to my handwriting). Occasionally I stop all programs to clear the memory.
Can you advise initially? - then I can fill you in on anything you might want to know.
I have found a few forum chats about this starting problem issue - one respondent suggested he do a hard reset, but isn't that a bit extreme? However, I may have to try it (if you don't have an easier solution).
regards,
Will (wdd.tea92@virgin.net)
  • HP Master
  • 20,706 Answers
Worst HP site on earth, but welcome!
never post email on any forum that be bad bad news.
why do that, erase that, want 1billion SPAM in one day
wow. that is scary, no?
like here
http://support.hp.com/us-en/product/HP-iPAQ-210-Enterprise-Handheld-series/3544499/model/3544500/
or here
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3544500
your A/C walls mains,power pack is no good
it runs on battery
is proof.
in most cased. only real tests, tell real truth'
but you have no meters, or know how to dismantile
this device.
Posted on Mar 01, 2017
  • Anonymous Mar 01, 2017
    but the hp.com books cover that.
    take it apart but not how to test it.
    but really all computers are the same
    von Neumann architecture and all that.
    first is power (DC power)
    all puters need regulated power
    wires break
    batteries die or short,
    regulators fail
    wall warts, (mains) get bad, week or dead )
    and more,but yours runs on batteries, ..
    some PC,s have 2 regs.
    one for main line
    one for battery, so it's really more isolated.
    but not all do that.
adib
  • 450 Answers
SOURCE: my iPAQ will not charge or turn on ...
Can you get the iPaq hooked up directly to AC power? There's apparently a charging threshhold for badly depleted batteries that the USB port cannot get over.
Posted on Sep 08, 2005
greenwallinc
  • 8 Answers
SOURCE: iPAQ Not Charging from AC Outlet
If you are not using the original chargers it could be the type of charging cable. Not all cables that fit will charge the device correctly.
Posted on Aug 12, 2007
XBRMann
  • 38 Answers
SOURCE: HP Ipaq rz1710
I have to agree with DirtyHarry1, it sounds like the battery could be weak. On my iPAQ when the battery is done charging the charging light changes from orange to green, I'm not sure if yours will do that. I'd try leaving it charging on the cradle for about 24 hours to see if that improves the life any.
Posted on Feb 01, 2008
rolltape
  • 58 Answers
SOURCE: Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Posted on Feb 05, 2008
Bogdan
  • 198 Answers
SOURCE: Ipaq 4155 wont turn on, dont charge, dont anything, is totally death
I had some similar experiences with these ipaq's when I was working in a specialised service center. I'll try to give some help or tips through the internet, altrough if i could have seen or diagnosticate these pda's myself it would have been more easier. First of all these problems have 2 main causes. Most of the pda's comply with one of them, it is very rare that a pda will develop this problem by having both causes.
The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
The second cause could be a major firmware / ROM memory corruption. These things can happen out from nowhere. In my time working for service centers I've tried to isolate a pattern for this problem but without much succes. However it seems that most of these problem tend to appear durring charging cicles due to power spikes or drops on the main AC voltage supplied to the charger. This is only a supposition, I'm not sure yet on this cause. What to do here? Well this problems are fixable but first of all you must be sure that this is a software problem, not a hardware one. So let's diagnosticate some things.
Try to charge the pda. Ignore any lights or beeps or whatever your pda is showing on the screen. As long as the charger is connected the charging process is based on the most primary charging circuits on the pda's motherboard. If the pda is not charging or cannot hold any charge (when you unplug it the screen fades away or it simply doesn't do anything else) maybe that circuit is broken (this is a a sign of serious hardware problems ) or maybe the battery is to old/weak. Batteries don't die out of nowhere, if you remember your pda to work and have some 2-3 hours of standby time it's imposible that now, suddently the battery has drained out so much that even if charged it can't hold out at least 30 min.
So we will assume that you charged the pda for at least 2-3 hours and you see some sign that the battery is working. The next step is crucial. TRY TO PUT THE PDA IN BOOTLOADER MODE. You will achieve this by pressing (and keep them pressed!) the following buttons : power, the far left and right buttons near the control pad (joystick or whatever some people call it) and reset button. You may need another person to help you press these buttons. the order should be the following (first power, then the 2 keys, then reset button for as long as it takes to enter bootloader mode). YOU SHOULD SEE A WHITE SCREEN WITH THE HP LOGO.
If your pda fails to do that, there is nothing more you can do to restore it in a DIY fashion. Probably the bootloader is corrupted or you have a hardware fault. Only a specialised HP service center can help you now. In most cases this will end up with a motherboard replacement.
If your pda does that, then there is a chance to fix it. We will need to probe the bootloader for direct data acces. This is needed for having the ROM memory (and operating system) rewritten. A small program called Mtty will be required to access the bootloader via an usb link.
Please make this tests first and then reply with your results. If anyone of you is in situation #2 there may be a chance.
Posted on Feb 10, 2008
Hp mini 210 bios download file binary original?
Hello, as Mike M says - need more information.
I can offer these two links 'into' HP site:
1) hp.com (USA) Drivers Software
2) hp.com (UK) Drivers Software this one, I found via HP Support page, link with title "Drivers & Downloads" HP Support Drivers Contact and Help Forums HP Support
If do search on "HP mini 210" in hp.com (UK) site, under Customer Support -> Drivers & Software. We get 54 matches: Drivers Software
Suggest you use product number/serial number for a more targeted search on HP site.
Regards
And...
Searching for HP mini 210 showing results 1 20 of about 1 000
Ya never know... :-)
Apr 08, 2014 | Computers & Internet
How to find IMEI on ipaq 214
Well, virtually all phones display their IMEI (International Mobile Equipment Identity) after typing *#06# on their dialer. However, as far as I know, the iPaq 214 is not a phone, and, as such, there is no sense talking about IMEI for this PDA. I might be wrong, though.
Please, let me know if you need further informations.
Regards,Carlos
Mar 08, 2012 | HEWLETT-PACKARD IPAQ 214 Pocket PC
How to pair a iPAQ 214 with an external GPS receiver?
It's pretty easy.
In your iPAQ 214 go on SETTINGS > GPS > and make sure the INCOMING CONNECTIONS are on CHANNEL 6, and for the OUTGOING CONNECTIONS are on CHANNEL 5.
Start the external GPS device, start your Bluetooth connection on your iPAQ and you're ready to go.
Mar 06, 2011 | Garmin nuvi 255W GPS Receiver
My ipaq 214 wont boot up. it just freezes on the HP screen. Ive tried pressing the reset button like over 100 times but it just freezes again. Ive also tried hard reset and that dosent work either. I have...
You could have a corrupted program on your PDA. You need to contact HP and have them re-flash or upgrade the firmware of your PDA and it should work much better than before.
Have a great day!
Oct 11, 2009 | HP iPAQ 214 Pocket PC
IPAQ 214 get stuck while working with FTDI driver
nobody uses these now
but why not ask hp.
they get a great laugh,
here it is wait for it, the REAL HP, (drum rollllllll)
https://h30434.www3.hp.com/
Oct 22, 2017 | HP iPAQ 210 Pocket PC
IPAQ 210 Stuck on Boot Screen
A "hard" reset work.  I thought I tried this earlier but I was pressing the wrong keys.
Aug 31, 2008 | HP iPAQ H2210 Pocket PC
HP iPAQ 5555
after full reset I am unable to access online capabilities
May 06, 2008 | HP iPAQ H5550 Pocket PC
Spares for Ipaq 6515
hi kanchan by going to this site http://www.ipaqrepair.com or http://www.techtree.comyou will get info about service centre's of ipaq on india for more info serach in web . good luck
Jul 02, 2007 | HP iPAQ hw6515 Pocket PC
AC charging issue
Sounds like a defective AC adapter.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
289 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
