Question about Lexmark Wheelwriter 1500 Typewriter
Light 1 always on, beeps when any key is pressed. No typing
I can't figure it out. It powers up, the print wheel will spin around during the power up phase and all the lights light up. The lights go out like it's ready to type and then when you hit one key, the print wheel moves a bit and then it all stops and that's when it starts beeping. From that point on, light 1 comes on and beeps when keys are pressed...
  • Lexmark Master
  • 3,594 Answers
I was just playing with a WW 1500 and the only way i got anything close to what you described was to stop the carrier on tab and return it so it slammed at the l. margin. Check and see if the carrier moves fairly freely from side to side with power off. If so check the circut board over and under for debris.
Hope this helps
DickyO
Posted on Feb 22, 2008
P3015 beep
Here are some possible reasons why your printer is beeping:
1. Your printer is connected to a UPS (Uninterruptible Power Supply). When the printer goes through the printing cycle it uses a massive amount of electricity. During those few seconds of power usage, the UPS will beep indicating that it will not be able to sustain that power output for any period of time.
How to fix: Move your printer to another outlet and don't connect it to a UPS
2. You have an MFP (multi-function printer) that is attempting to fax again and again. When sending a fax, it's typical that the printer makes noises (dialing, connecting, etc). One of these noises is a fax response beep.
How to fix: Check your printers menu and turn off/down the fax volume
3. Some printers with an LCD menu and keypad make noise when keys are pressed or the printer encounters an alarm of some type. This can become annoying when typing keys for a phone number or by changing a menu setting.
How to fix: Check the menu settings for the printer and turn off/down the sound that's occuring. As an example, the HP LaserJet MFP series printers have the following sounds.
  • The alarm sound that the printer makes when it requires attention, such as when the all-in-one
    door is open.
  • The beeps that are emitted when you press the all-in-one control-panel buttons.
  • The phone line sounds for outgoing faxes.
  • The ring volume for incoming faxes.
As an example, change alarm volume by following these steps (using a 305X series printer)
1. Press Menu
2. Use the < or the > button to select System setup, and then press the green checkmark button
3. Use the < or the > button to select Volume settings, and then press green checkmark button
4. Press the green checkmark button to select Alarm volume
5. Use the < or the > button to select Off, Soft, Medium, or Loud
6. Press the green checkmark button to save your selection
Mar 20, 2014 | Office Equipment & Supplies
Keyboard want work
If your machine is not printing properly:
1.Examine the ribbon cartridge to make sure it has not run out of Ribbon. If your ribbon appears silver or gray, install a new cartridge.
2. Ensure the black lever in the center of the carriage is pressed to the rear, towards the paper. If not press it to the rear to lock the Daisy Wheel into place.
3. With the typewriter turned off, press and hold down the "CODE" Key, the "SHIFT" Key, and the "TAB" Key.
4.Restore power with all three Keys depressed.
5.When the machine sounds a beep tone, release all three keys.
6.The carrier will move to the left indicating that the memory has been cleared and the machine has been reset.
7.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com/service/default.aspx
May 08, 2013 | Brother EM-530 Typewriter
Hp games 18 wheels steel unlock code
LDXC-JKTD-LAAR
Cheat List
Alter game files at your own risk and always make backups!
Find the 18 Wheels Of Steel Haulin' folder. Go to the configure file and change:
'uset g_console "0"' to 'uset g_console "1"'
And also change 'uset g_developer "0" to uset g_developer "1".
During gameplay, press the tilde (~) key and type the following commands to make certain things happen. (don't type the " things)
  • -"cheat money" - receive $500 000 instantly
  • -"cheat driver" - add a random driver to your fleet (press UP for infinite drivers)
  • -"cheat rating" - view list of companies
  • -"cheat rating " - increase the company ratings for that specific company
  • -"cheat company " - List branch offices for specified company
  • -"cheat company " - Teleport to specified company and branch
  • -"edit" - Map/world editor
  • -"exit" - Return to main menu
  • -"quit" - Quit game
  • -"sys_info" - Display operating system information
May 06, 2013 | Compaq Computers & Internet
Can i lock the controls on my jazzy 1121
This is taken from the owner's manual from the 1121 with a VSI controller:
I suggest you print this out and keep it handy.
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
Jul 01, 2012 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Personal Wheelwriter, the daisy wheel spins the carrier spaces to the right then it beeps..it keeps doing this til lit hits the right margin. tried anothe print wheel, no change.
It's not completing the power on reset probably a board or power supply. If you have the ability remove the board and look for debris on and around it.
DickyO
Oct 01, 2010 | IBM Wheelwriter 30 Typewriter
BJC-85 canon printer.....brand new cartridges both b&amp;w and color. Error light chimes 8 times and won't print
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printer starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beep
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Aug 07, 2010 | Canon BJC-85 InkJet Printer
Resume light flashes and beeps. Lost its mind and
Try this:
F14 Error Reset
1: Unplug adapter
2: Hold POWER
3: Plug in ADAPTER
4: Release POWER after printer starts
5: Hold FF and MENU and press POWER
6: Release after beeps
7: Press <> Cartridge until 1D is displayed
8: Press ONLINE
9: Press POWER to shutoff printer
10: Unplug printer then replug printer
Jun 15, 2009 | Canon BJC 80 InkJet Printer
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
Error and power light blinking.
Here is the Waste Tank Full reset.
Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70
4: Release buttons after the printers starts up
6: Press POWER
7: Release all buttons after the beeps
9: Press RESUME
Mar 30, 2009 | Canon BJC-85 InkJet Printer
PROBLEM COPYING WITH MY ALL- IN- ONE
This message is inbuilt into most Canon printers, there is spongy thing in the printer which when fills up fires the message (it's mostly a counter in the printer, which can be reset more later...), per Canon this can only be dealt with in a lab but some of the more adventurous have tried cleaning it by themselves. Note that in a lab they won't clean it, it's a part that needs replacing and it might cost around $60. In most Canon printers there is a reset procedure that can reset the error and allow you to print some more before handling it again. Following are the reset procedures for some of the Printers: (not that F60 isn't listed here) Canon GENERIC "S" SERIES RESET CODE Waste Ink Counter Reset. (1) Turn off the printer. (2) Press and hold the RESUME button, then press and hold the POWER button. (3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will "reset" or move momentarily. If the above was properly performed the printer will enter the "Service Mode". (4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. 1. Service/Factory test printout, including ink sensor check. 2. EEPROM - Info printout. 3. EEPROM - Initialization. 4. Reset the Waste ink counter. 5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!) After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer. ++++++++++++++++++++++++++++++++++++++++++++++++++ Canon PIXMA iP1000 Waste Ink Counter Reset Manual for Service mode 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. ++++++++++++++++++++++++++++++++++++++++++++++++++ Canon PIXMA iP1500 Waste Ink Counter Reset. Manual for Service mode 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green 6. Release both buttons ++++++++++ ++++++++++ ++++++++++ ++++++++++ ++++++++++ Canon i320, i255 Waste Ink Counter Reset. Step 1 : Manual Temporary 1. Unplug power and USB. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button. or Step 1: Manual Temporary 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. step 2 : Software for Permanant 1. Reconnect the printer cable. 2.Open General Tools software and select (USB PORT) 3 .Choose (SET DESTINATION 1) And it should be reset. Remark "After service mode Pls use software for permanent reset" ++++++++++ Canon i850, i950, S600 Start with the printer OFF 1. Hold down RESUME and then hold down POWER 2. release RESUME 3. press RESUME twice, then release POWER 4. Let green light blink until printer is done futzing Select function with RESUME press POWER to execute: presses - light color - function Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter ++++++++++ Canon S450 Printer 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5. Release Power button 6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 7: Press Power to set data ++++++++++ Canon BJC 1000 Serie 1: Remove Cartridge 2: Unplug the AC Power Cord 3: Hold down the RESUME button 4: Release RESUME after plugging in the AC Power cord. 5: Press the RESUME once within 5 seconds and release the RESUME . 6: Press and HOLD RESUME for two seconds or more and release it. 7: Press and HOLD RESUME for two seconds or more and release it. 8: Unplug AC Power Cord to set data. ++++++++++ Canon BJC-2000 BJC-2100 Serie 1: Remove the Cartridge 2: Unplug the AC Power Cord 3: Close Front access panel 3: Hold down the RESUME/RESET button and plug in the AC power cord 4: Release RESUME/RESET after plugging in the AC Power cord. 5: Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET . 6: Press and HOLD RESUME/RESET for two seconds or more and release it. 7: Press and HOLD RESUME/RESET for two seconds or more and release it. 8: Unplug AC Power Cord to set data. ++++++++++ Canon BJC-210 BJC-240 BJC-250 BJC-255 BJC-265 Canon BJC-4100 BJC-4200 BJC-4300 BJC-4400 BJC-4550 BJC-4650 Unplug Power Cord Hold POWER and RESUME buttons Plug in Power Cord Release buttons Open front door of printer Hold the CARTRIDGE and RESUME buttons Press POWER Release all buttons after the beeps Press CARTRIDGE once Press RESUME ++++++++++ Canon BJC-5000 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN. 6: Press Power to set data Service Test Print 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN. 6: Press Power to Print Nozzle Print 1: Power off printer 2: Press and POWER, until the printer beeps and release. Demonstration Print 1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps. ++++++++++ Canon BJC-5100 Self Test Switch Printer off. Hold Power for 1 beep. Waste Counter Reset 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN. 6: Press Power to set data Service Test Print 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN. 6: Press Power to Print Nozzle Print 1: Power off printer 2: Press and POWER, until the printer beeps and release. Demonstration Print 1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps. ++++++++++ Canon BJC-3000 BJC-6000 BJC-6100 BJC-6200 S400 S450 F300 F600 F620 Canon BJC-7000 BJC-7100 BJC-8000 BJ-F800 i6500 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data ++++++++++ Canon BJC-600 BJC-600e BJC-610 BJC-620 1: Unplug Power Cord 2: Hold POWER and FF and Print Mode buttons 3: Plug in Power Cord 4: Release after the beeps ++++++++++ Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70 1: Unplug Power Cord 2: Hold POWER and RESUME buttons 3: Plug in Power Cord 4: Release buttons after the printers starts up 5: Hold CARTRIDGE and RESUME 6: Press POWER 7: Release all buttons after the beeps 8: Press CARTRIDGE 16 times 9: Press RESUME 10: Unplug the Power cord ++++++++++ Canon BJ-30 BJC-35v BJC-70 F14 Error Reset 1: Unplug adapter 2: Hold POWER 3: Plug in ADAPTER 4: Release POWER after printer starts 5: Hold FF and MENU and press POWER 6: Release after beeps 7: Press <> Cartridge until 1A is displayed 8: Press ONLINE 9: Press POWER to shutoff printer 10: Unplug printer then re-plug printer ++++++++++ Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520 Turn off the printer. Press and hold the RESUME button, then press and hold the POWER button. Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily. You are now in Service mode. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press. 1. service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone) After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a resta ++++++++++ Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA IP3000 above, 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal. +++++++++ Canon S900, S820, S750, S520 Turn off the printer. Press and hold the RESUME button, then press and hold the POWER button. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press. 1. Service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone) After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart. ++++++++++ Canon S9000 Turn off printer Hold down Resume button and press Power button. Keep holding down Power button and let Resume button go. Press Resume button 2 times then let BOTH buttons go. Green lights will flash and then stop blinking. When green lights are solid, press the Resume button 4 times. Press the Power button and the printer should turn off, if not, press the Power button once more. Your printer should respond as normal. +++++++++ Canon MPC190 Reset Waste Ink 1) Enter SERVICE MODE. By pressing Menu Copy Scan Copy Copy 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [Set] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jul 26, 2006 | Canon MultiPASS F60 All-In-One InkJet...
Lexmark Wheelwriter 1500 Typewriter Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
