Question about Belkin (F5D7230-4) Router (587009)
Cannot access
I used to be able to connect to it still sends wireless signal to tivo and computer is connected directly to it via ethernet worked before....tried it fried?? it tries to connect an load but "The server at is taking too long to respond."
  • 1 more comment
  • jbird2009 Feb 15, 2008
    tried soft computer is pluged into the back of this router but still I cannot access the router directly like I have in the past "
  • edmat Feb 17, 2008
    I have a Belkin G Router F5D7230-4 that just stopped working properly all of a sudden. Going to their website didn't help much because I am unable to access the "" page. Any suggestions?
  • wallahham Mar 28, 2008
    dear friends
    i have the same proplem the belkin dont take an ip in the network conection details it takes like a virtual ip in autoconfigration ip4 " " and in the supnet mask and nothing in the ip4 or ip 6 dhcp enabled
    i tried reset
    any one can help
  • Belkin Master
  • 19,396 Answers
Did you disable any firewall present on your computer? they may prevent from acessing the router. In any case, if you want to be sure of the ip of your router then press run from start menu. Then type in 'cmd'. it will open the command prompt. in the command prompt type 'ipconfig /all' and press enter. the router ip will be indicated as 'default gateway. If it still does not work try opening the router page with a different driver. You can download mozilla or opera browser.
hope it helps
Posted on Feb 16, 2008
On You Tube my NETBOOK computer spends massive time buffering...the exact same videos play non stop on my other laptop....I have de fraged andcleaned up the disc but still super slow video streaming
Posted on Sep 02, 2010
    Brigadier General:
  • 3,614 Answers
There's no problem on your device, try again a soft reset.
Posted on Feb 15, 2008
  • micromaster
    micromaster Feb 16, 2008
    Uninstall everything the router & your interface card. & then re install it again.
How to change host on mc9090
Wireless Local Area Networks (WLANs) allow mobile computers to communicate wirelessly and send captured data to a host device in real time. Before using the mobile computer on a WLAN, the facility must be set up with the required hardware to run the wireless LAN and the mobile computer must be configured. Refer to the documentation provided with the access points (APs) for instructions on setting up the hardware. To configure the mobile computer, a set of wireless applications provide the tools to configure and test the wireless radio in the mobile computer. The Wireless Application menu on the task tray provides the following wireless applications: • Wireless Status • Wireless Diagnostics • Find WLANs • Manage Profiles • Options • Enable/Disable Radio • Log On/Off Tap the Signal Strength icon to display the Wireless Applications menu
pg 1-13,
Download manual
Apr 07, 2015 | Symbol Motorola MC9090 Mobile Computer
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
on Oct 02, 2013 | Tivo Premiere 4
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
Oct 27, 2009 | Computers & Internet
I keep losing the internet signal and going offline. LAN indicates pending??? How do I perform a system reset with Linux??
Power cycle the system by shutting it down and switching it on after at least thirty seconds. Check network settings to verify the IP address and other related information. Determine if the network card is working adequately. Identify the malfunctioning adapter by disabling the cards one by one. Move one of the portable hosts--such as a laptop--closer to the router. If it works better, interference or low signal strength is the reason for poor Internet access. Inadequate signal performance can be caused by several factors including cordless devices working within the frequency range (2.4 GHz) of a wireless network, shiny surfaces and too much distance between hosts and access points. Resolve this issue by using a wireless repeater?a device that amplifies wireless signal so it reaches distant areas within the premises. Minimize signal interference by maintaining a distance of at least one meter between cordless devices and the router. Alternatively, buy gadgets that function at frequencies other than 2.4 GHz. Try changing the WiFi channel for better results. Check the functioning of wireless router and access points. Adjust the router antenna to get an optimum signal. Most wireless routers come with omni-directional antennae to send signals in all directions, a situation appropriate for a square-shaped network. If hosts are arranged in a linear fashion, use an antenna that sends signals only in one direction. Some portable routers have internal antenna, giving more freedom to users who are on the go. Use an external antenna with such routers. The market now offers antennae with varying strengths, implying some are more powerful than others. See if using a more powerful antenna fixes the problem. Aside from increasing the range of transmitted signals, the reception capacity of hosts can also be enhanced. External WiFi-enabled antennae attached to laptops are now available for this purpose. Change the location of the router and access point. They should ideally be placed centrally between all computers. As the signal bounces off smooth and shiny surfaces, routers and access points should be placed away from windows, doors, mirrors and other metallic surfaces. Examine signal performance by using the monitoring utility that typically comes with the access point. Check that the devices show correct lights. Device lights are an indicator of accurate connections. Different lighting patterns indicate different things. For example, some network cards show green light on successfully establishing a connection. Similarly, the router's wireless LAN (WLAN) light is turned on at all times, even if no device is connected to it. Further, this light blinks when a host communicates with another host. Unexpected lighting indicates a problem. Go through user manuals to get familiar with this feature and make sure the devices show desired lighting behavior. Use wireless Internet utilities to check the SSIDs and channels neighboring wireless networks are using. Change your network's SSID and/or channel if they are the same as that of other networks in the vicinity. See if correct drivers have been installed. Check configuration settings for encryption keys.
Sep 24, 2009 | ASUS Eee PC 2G Surf Notebook
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ? to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Jul 22, 2009 | Computers & Internet
2005 FORD F150 AC blows cool/warm in front and cold n back vents
Check i the truck comes with separte a/c units, if the front is warm check for an open heater valve, if ok, check for proper gas pressure.
Jul 08, 2009 | 2005 Ford F-150
The camcorder doesnt reset anything. The mini DV still stuck in
Networking Configuration A network architecture is a set of standards for how computers are physically connected and how signals are passed between hosts. Some typical network architectures are described in the table below.
Network Architecture Description Ethernet Ethernet is a wired networking standard and is the most common networking architecture used in LANs (both in business and home networks). Dial-up Modem Dial-up networking is a common way to connect a computer (often your home computer) to a remote network, such as the Internet or a business network. A modem on each computer uses the phone lines to send and receive data. DSL (Digital Subscriber Line) DSL is a fast-growing alternative to dial-up networking to connect to the Internet. DSL uses regular phone lines to send digital broadband signals. ISDN (Integrated Services Digital Network) ISDN is another alternative to traditional dial-up that can be used to connect to the Internet or to directly communicate with another computer connected to the ISDN network. ISDN is more common in Europe than in the U.S. ISDN can use regular telephone wiring, but must be connected to a special ISDN network. Wireless Wireless networking uses radio waves or infrared light (with the air as the transmission medium) to send data between hosts. Wireless networks are common in homes, businesses, airports, and hotels. Most wireless networks connect into larger wired networks (such as LANs) which are in turn connected to the Internet. Communication between hosts on a network generally takes one of three forms:
  • Simplex--one-way communication from a sender to a receiver.
  • Half-duplex--two-way communication between two hosts. Communication only travels in one direction at a time.
  • Duplex--two-way communication between hosts. Communication can travel in both directions simultaneously.
Jul 08, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
Belkin WirelessG Plus Mimo
I'm pretty certain that you can only have 1 host per computer/per name for a network. So, if you want to change the laptop as host you will have to setup a network under the settings. Create a network password along with the network name for that laptop. (Unidentified Network) is a correct network name. It's just that you probably didn't change it to a specific name that you wanted it to be in the box. after doing this, you should be able to go to the other computer's and try to log onto the network domain that you have created. after that in order to get approval to access the network domain you have to enter the encryption key which is the network password. you have to do this to all non hosted computers. after completion, you should be connected to that specific network.
Now you want you're desktop to be the host. Well, from above do the same steps for the desktop. But, instead of (in example) to lets say your laptops network name is (Home). Well, you would have to make the host name on the desktop to be (Home2). then set the encrption key. Then go to all non hosted computers including the laptop that you made the first network. because this is a new hosted network created by you're desktop and connect to that network and then supplying the encrption key to be able to access the network. and you should be good. Just my 2cents. although this may not work because you may have to have to routers to be able to create multiple networks but, like you mentioned earlier you have a wireless on you other laptop you can use the setup for that wireless to make another network. Hope this helps and good luck ;)
Dec 02, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless internet connection
You haven't specified if the host computer is able to access the internet. Ip Address confict can be one of the reasons why the laptop isnt able to connect and we can have a series of reasons why we have this IP Address conflict - 1) There is no wireless encryption defined. So, we have neighbors connecting to the wireless network causing IP Address conflicts. 2) The laptop is not able to renew the IP Address after the lease expires. This can mostly be resolved by restarting the computer and in certain cases flusing the TCP/IP stack. 3) There is a static IP Address assigned to the laptop in the router's DHCP range which is conflicting with the host computer. I would suggest you may initiate a chat with me or anyone else who has expertise in routers to get this successfully resolved. That would definitely save your time. Good luck
Apr 22, 2007 | HP Pavilion dv8000z Notebook
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Belkin (F5D7230-4) Router (587009) Logo
1,280 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
