Question about Cyberhome CH-LDV 707B Portable DVD Player
Spinning dvd's for cyperhome dvd player
Doesn't play any cd
  • 42 Answers
Check out the spindle motor ... i'll bet it is defective!
measure with a ohm-meter the impedance while gently and verry slowly turn the motor . I'll bet the impedance shows conciderable fluctuations . It should be always at the same ohms. about 10 ohms.
Posted on Jul 09, 2009
    Problem Solver:
  • 14 Answers
These units have a problem with the power supplies basically the same as a computers +5 +12 and a ground i usually throw them away unless i have a small p/s laying around that i can throw int them. usually one from an old external hard drive works quite nicely. if yor no mechanically minded w-mart sells them for around 29 bucks.
Posted on Feb 24, 2008
    Sergeant:
  • 280 Answers
Is the cd spinning? If so it is most likely the Laser. Try to clean the lens "gently" Put a little light oil on the rails that the laser rides on. if that don't cure your problem then the laser is most likely burned out. Cost to replace would be more then that unit is worth These units are china made players that are considered throw aways
Posted on Feb 22, 2008
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
WHEN I PRESS PLAY ON MY CD PLAYER IT DOESN'T SPIN.HOW DO I FIX IT
your cd drive in system not detect cd clean lens using lens cleaner and try to play
May 19, 2012 | Venturer CD-2160 Shelf System
My handheld dvd player isn't reading the disc-they just spin really fast
Spray an small drop of safe window cleaner onto a Q-tip. Clean the laser lens carefully and then use the other end of the Q-tip to dry it. Use compressed air on and around the laser lens (do not blow on it). Clean your DVD disc and try again. If it fails again, try using a CD, if it will play a CD and not a DVD your optical pickup assembly is defective. If the CD wont play at all, your optical sled or spindle motor and/or drive is defective.
Most cases if cleaning doesn't fix it, it's cheaper to replace the entire DVD player. All portable DVD players are junk, regardless of brand.
Jul 18, 2011 | Video Game Consoles & Games
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Mar 16, 2009 | Zenith DVP615 Portable DVD Player
Noise while playing cd or dvd
the top spin needs more plastic grease
Mar 11, 2009 | Audiovox VM9311TS
Need instructions to set up Cyberhome DVD 1200 player
Useing RCA cables -(yellow video out) on the dvd go's to yellow video in on the tv. Then (red -right) out on dvd go's to red audio in on the tv . And white-left out on dvd go's to white-left audio in on the tv! and thats it
Dec 24, 2008 | Cyberhome Televison & Video
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Cyberhome CH-LDV 707B Portable DVD Player Logo
79 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
