Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
PC will not recognize jumpdrive
My computer will not recognize my jump drive. I have tried to read it from serveral computers; Verbatim 1GB
  • Anonymous Feb 24, 2008
    i have a problem for my pendrive the pc not recognize it then this is said that unknown device
    rgffgh
I want to transfer music from one computer to another using Lexar jumpdrive s5032 gb. How to do that
Upload the files to the jumpdrive. Remove jumpdrive from computer 1 and insert in computer 2. When computer 2 recognizes the jumpdrive, copy the files to a directory folder where you want to save the music. Unplug the jumpdrive.
May 13, 2015 | Lexar JumpDrive S50 32 GB USB Flash Drive...
I have a 16 GB verbatim brand jump drive that I cannot open up. I have tried other usb ports on different computers. Is it common for jump drives to go bad? Do you have any suggestions? Thank you!
If not "safely removed" USB drives can go bad. If your system recognizes the drive when plugged in you can try doing a scan disk on it and check for any errors that may be preventing you from accessing the file system.
Plug in the USB drive, check my computer and see if the drive is there, if it is, right click the drive, click properties, and tools and select the option to scan the disk.
If you do not see the drive in My Computer, click start, Run, type DISKMGMT.MSC and click OK. Check and see if your drive is being recognized in Disk Management.
If you still do not see it in Disk Management, they you may just have a faulty jump drive, at which point you should contact Verbatim to see if they have any other recommendations or if it is still under warranty.
Jul 06, 2011 | Computers & Internet
All of a sudden no computer will recognize the
These drives do die from time to time. If a comp wont see the drive....it's dameged ...sorry. :(
Feb 19, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
My pc doesn't recognize my verbatim 1000gb external hard drive, error "unknown device"
Did the 1000gb external hd come with instructions?
Did you read them?
Did you Install The Software for this Device?
If not. Try plugging it in all the usb ports.
Try shutting down the PC, when it's off plug in the 1000gb external HD,
Restart the Computer, If Windows still dosen't recognize it, then it's most likely defective, and should be returned. Try purchasing a higher quality brand.
Nov 20, 2009 | Verbatim VER95327 USB Hard Drive
2gb jump drive not working
There are two major possibilities:
1: There is hardware or software problem with your computer's USB ports. To test this, plug the drive into a different computer if you can, and try having it plugged into your current one while you turn the computer on.
2: The issue is with the Jump Drive itself. If the drive fails to show up when plugged into a different computer this is the likely problem. The data CAN be recovered, but if it won't show up on any computer, the only real way to do so would be to pay a Hard Drive recovery shop.
Sep 21, 2009 | Verbatim VER95327 USB Hard Drive
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
I have a lexar 1 GB jumpdrive secure 2 plus and was using it to save pictures. In the middle of trying to save a picture a notice came up saying i couldn't save it because the directory was full. how do i...
In that case I have two suggestions. *note I am assuming you are using a computer with Microsoft Windows.*
One: Defragment the jump drive. With the jump drive plugged in click on the 'start button' and choose 'My computer'. Then right click the jumpdrive and select 'properties' which will open a window. Click on the tools tab and select defragment.
Two: Format the drive. First, if the drive will allow, copy the data fron the jumpdrive to your computer. Then click on the 'start button' and choose 'My computer'. Then right click the jumpdrive and select format. Let me know if you have already tried this or if you need more clarification.
Hope that works for you.
-WN
Aug 13, 2008 | Computers & Internet
Verbatim 1GB flash drive data recovery
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Jan 22, 2008 | Electronics - Others
Lexar jump drive
Take it to a Wal*Mart for an exchange
Dec 04, 2007 | Lexar MEDIA - DIGITAL CAM - 64MB JUMPDRIVE...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
187 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
