Question about Kenmore 46564 / 46565 / 465 / 6646569 Electric Kitchen Range
Kenmore Electric Range
Model 911.4654090 Serial # 4M202793Q
The display on the front of the unit is displaying F-1 and alarming. What is the problem? The burners and oven appear to work OK, but it alarms. I tried turning off the breaker and turning it back on, but it went right back to alarm.
  • JeanK38 Apr 23, 2008
    after the oven is operating for 20 to 25 minutes the F3 alarm sounds. I turn the oven off however, about 20 minutes later the F1 alarm sounds. This is soundig when the oven is off. I pushed the CLEAR/OFF again and this stopped the alarm. What is wrong here?
  • 770 Answers
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Posted on Feb 15, 2008
My Kenmore electric range model #970-6784 displayed an F10 error during the cleaning cycle and started beeping. I can't clear the error or stop the alarm from beeping. Any Suggestions?
that means the temperature was "run-away" or unable to be controlled safely. To reset, unplug the main power or turn off the main circuit breaker. I would test it again as you may need a repair person if the error happens again. It can relate to a bad temp sensor.
Jan 02, 2018 | Kenmore Kitchen Ranges
How do I make it shut up?
You probably have an error conditon. Is anything displayed on the control panel? If it's displaying "PF", that means "Power Failure". Press the STOP or CANCEL button, then set the time. That should stop the beeping (if it's displaying PF). if any other error code is displaying, I would need to know your range model number, and the code that was being displayed.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 13, 2015 | Kenmore Electric Smooth Top Stove
Kenmore Model 790. Burners work but the electronic buttons and the oven do not work. Is there a fuse for this? None of the display works or lights up.
You will need the control board for your range. I can direct you to the part if you can post the model number off the unit. Look in the oven for it.
Aug 03, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Alarm comes on and display shows f7 code
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
On a sears kenmore electric range 790, my mom accidently held the time of day display off by pressing the clock button and holding for more that 15 seconds. (page 13-bottom, if you have a manual). She...
My kenmore electric range model 790 bake element don't work ,and every time I try to use it only the upper element work to preheat and it start to beeb and give me sign of( f 10) . A .A
Oct 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Beeping sound and f8 displayed
F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Alarm fault code
f-2 is a faulty temp sensor. replace the oven temp sensor to solve problem
Nov 19, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Kenmore 46564 / 46565 / 465 / 6646569 Electric Kitchen Range Logo
252 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
