Question about HP Compaq Presario V2000 Notebook
Compaq laptop/no boot up
Upon power up 2 beeps, display briefly flashes Compaq logo then says "Press to resume, to Setup. Keyboard non-responsive.
  • 9 more comments
  • gryeden Feb 16, 2008
    thanks, but already tried removing/replacing HD, CDrom, and memory modules, so it looks like this thing is bound for compaq tech center for repair.
  • Anonymous Mar 06, 2008
    I've got the same problem, please if someone fix the problem post de solution.
  • Sumit Bisai Mar 08, 2008
    On pressing the Power Button, while starting, it just holds on showing the label of COMPAC, and doesnt proceed further. Even F10 and F12  button have no effect over it. I have to keep restarting it several times, and just randomly after few trials it starts up.
  • Anonymous Mar 10, 2008
    I have the exact same problem. I cant even access the BIOS **thing works.
    I tried switching the RAM but ** luck.
    I only get the "two beeps of death"
  • Anonymous Apr 01, 2008
    F1> to resume, to Setup. Keyboard non-responsive
  • Anonymous May 05, 2008
    mon computur compaq il demarre de boot je peux un soutution pour ne pas demare de boot q'est ce que je fais
  • Anonymous Oct 08, 2008
    same thing as everyone describes
  • shane4d2 Oct 08, 2008
    same thing everyone describes.
  • jeetu 971815 Oct 11, 2008
    I m jeetu i have aproblem.i have intel 945 motherboard. in evening i switch off my pc. but in the morning it give three beeps but it not give any display on monitor
    I have my pc its cd rom always opening when i open my drives or any folder. plz give answer as soon as possible.
  • overdrft May 11, 2010
    Solution link . . . www.Laptop-Problem-Sollution.com
    Problem Solver:
  • 11 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
    Problem Solver:
  • 11 Answers
You could try a usb keyboard and mouse, i had a pc that wolud beep twice when no keyboard was detected and power off, maybe the ribbion on the cable is faulty or the connector to mainboard.
can you enter bios to change values, ie can u change boot order?
check all connections on hard drive, cd,keyboard, touchpad.
you can rule out any virus or software related issue. its hardware related, have you got acess to a POST card, they are cheap these days and can tell you a lot.plug into usb slot and boot.
Posted on Apr 23, 2009
Did you ever figure out how to fix this problem?
Posted on Oct 08, 2008
  • shane4d2 Oct 09, 2008
    I'm having the same problem, and it will not boot of any CD. As soon as it turns on, it flips immediately to the to resume, to Setup pops on. No CD will boot, and you can not hit any keys or anything. could this be caused by a bad or corrupt (virus maybe?) MBR?
You need to got into bios and try starting from a os cd or try using a live cd (linux)
Posted on Aug 22, 2008
Update...ordered and replaced keyboard upon local pc techs recommendation...no joy.. Also tried booting off a linux live cd..again no joy. Same reaction as initially posted..What do I change next?
Posted on Mar 11, 2008
  • 520 Answers
Have you tried starting pc with a os disk in cd drive to see what bios say(startup from cd for instance) .
sounds to me like parts of operating system missing and system is detecting no os.the system doesnt look for a hd it looks for os if it finds no os or os damaged;it assumes no hd thus 2 beeps.try install new copy,partition drive ,format and install.unsure bout this let me know.
points to consider....you get a logo means video fine,bios fine,memory fine.options to resume or enter setup indicate hd ok.two beeps mean something missing or not recognised.
stick windows in cd and startup,boot from cd(install or repair)
Posted on Mar 08, 2008
  • tat4u
    tat4u Mar 08, 2008
    forgot to ask ;have you had the keyboard off at all.if so the ribbon has not been replaced correctly.
    Brigadier General:
  • 6,966 Answers
Initially it may be suspected that your laptop is detecting a hardware problem, probably the hard disk. Since it partially boots and there is display, the following can be ruled out: video card, memory and display systems. That would leave us the hard disk and the motherboard left. If the motherboard is in question, chances are it is the BIOS.
Pls try and verify that the hard disk is connected snugly. The hard drive is usually inside one of the slots covered by a panel/lid held by a single screw.
If your concern has not been corrected after completion of the above procedures, further diagnosis may be required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 15, 2008
Compaq V2000 "Press <F1> to resume, <F10> to Setup
re install the operating system.insert the recovery disk and follow the instructions.
Feb 20, 2010 | HP Compaq Presario V2000 Notebook
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Cant See Post
The 2 beeps are an error code. It can mean a couple of things; 1. Bad or improperly seated RAM; or 2. Bad or improperly seated video card. The F2 option will take you into bios setup. But I would try the video card option first as it is the usual culprit in this situation. Hope this helps & please rate this solution fixya. Thanks.
Feb 06, 2009 | Compaq Presario M2000 Notebook
Prosario V2000 boot problem
This means that there is some component was not fixed well.
this error means: " press esc to change boot order"
"press F10 for setup press F12 to boot from lan"
with 2 beeps " that the system cannot find hard drive:
fixed every thing: and try this. if prompted to go setup , continue and find "load bios setup default and then save and exit.
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Troubleshooting my compaq
Best would be to get an anti-virus original disc (or rescue disk created on a clean pc) and have it boot from it rather then your normal operating system. other then that, have you tried to immeditaly press F8 just before it brings up the blue screen? you should be able to pick SAFE MODE from there and usually get it to work and inspect things.
Oct 29, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
1,242 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
