Question about Kyocera Mita KM-2050 Printer
Printer not receiving jobs from computers in office..HELP!
I don't have a lot of information. I came in the office yesterday morning and tried to print some docs, the printer wasn't responding at all and after a minute or so my computer would say that it failed to print. I look under the "printers/faxes" under My computer and everything looks normal. All of a sudden, it's just not receiving jobs. I tried to turn of printer, then turn of my computer, then I turned the printer back on and waited for it to be ready, then I turned my computer back on. Still, nothing!
  • Narissa Gajadhar Jan 16, 2009
    Unable to print documents, fax is OK, scan is OK
    Unable to print documents, can fax & scan to computer but not print. print error comes up.
  • 523 Answers
What type of connector do you use? if its network printing then check ip address, cable, and the network card of the machine if it shows light, if its usb cable check the driver or cable.
note: make sure when you press the print buttom on the machine it doesnot show offline! if it shows offline you cannot print hit go or start to make it online.
if none of this work, reset the machine by hitting 1087 twice this will take you to maintenance mode then hit 906 then start, highlight the words that come on screen by your finger then hit start, the machine will ask you to put the main power on and off, do that and you will be fine.
Best Regards
Posted on Mar 01, 2009
2 Suggested Answers
  • 157 Answers
SOURCE: i have hp laserjet 1020,
Open hp 1020 from start-settings-printers,then go to FILE-UNCHECK PRINTOFFLINE.
Posted on May 27, 2011
Yesterday I printed a page and could not print second page, so i shut everything down, this morning i turned on my computer and the printer started up & started printing & ran till out of paper....
Disconnect the printer power plug from the wall for 2 mins and plug it back in and turn the printer on and turn on your PC and see if that helps. The printer has a memory which stores information you may have sent to the printer. If you kept hitting the print button then it may have saved all those print commands in memory and it is printing that out. That is what happens most of the time at my office. So you need to erase the memory by turning off the printer from the wall. Hope this helps
Aug 14, 2010 | HP Office Equipment & Supplies
Canon IRC3200N warms up from cold when printing first job
One way is to leave the iRC3200 in standby mode and have one the office servers or office PC's to have ajob scheduled to print a 1 page startup job at 0835 so that the unit is ready for everyone at 0845.
Nov 12, 2009 | Canon iRC3100 Printer
Canon IRC3200N warms up from cold with first print job
Nov 12, 2009 | Canon imageRUNNER C3200 Copier
Need to print a report of past print jobs
If you have CentreWare IS you can do the following (taken from the manual):
You can find the manual link here: http://www.office.xerox.com/userdoc/P6250/6250_Web/pdfs/reference_guide.pdf
On page 97 of the manual it states:
Using Printer Management Features
Job Accounting
The printer stores information about print jobs in a log file. The log file is stored either in the
printer’s memory or on an optional hard disk if one is installed in the printer. If the log file is
stored in the printer’s memory, it is lost when the printer is reset. It is recommended that a hard
disk be used for job accounting.
The log file lists job records. Each record contains fields such as user name, job name, pages
printed, job times, and toner and ink used. Not all fields are supported by all printers. For
information go to CentreWare IS online help or CentreWare Web online help.
The job accounting values reported vary depending on the protocol and print command used
when each job was printed. For example, using NPRINT over NetWare provides the printer
with the most information about the job being printed. When using Windows and NetWare, the
job name is often LST: or LST:BANNER. Other jobs from other ports may provide less
information about the job.
Job accounting is available through CentreWare IS and CentreWare Web.
Using CentreWare IS
1. Launch your web browser.
2. Enter your printer's IP address in the browser’s Address field (http://xxx.xxx.xxx.xxx).
3. On the right side of the main CentreWare IS page, click Jobs.
The “Job Accounting Links” page provides links that enable you to browse, download, and
clear job accounting records.
For complete information on CentreWare IS job accounting, including clearing job
information, downloading job information to a file, and job accounting file formats, go to
CentreWare IS Online Help.
Hope this helps!
WizardRepair
Jul 17, 2009 | Xerox Phaser 6250DP Laser Printer
I hav installaed new cartridges but the is offline and i cant
I have a Printer problem - "Ink System Failure" - Ink System has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc18a001". This is what the glass on the left side says. I don't use faxes, so don't care of that. My Son installed an ink system, which of course is a lot cheaper to use, quite some time ago which has been working super. Yesterday the "Ink System Failure" sign came on and my Son was here this morning, but couldn't figure out what is wrong with the printer. I am in Heidelberg, Germany and buy my equipment in the AAFES PX. There is no HP technical service available to us Military people. The Germans won't work on American goods. Is there any hope for me? Thank you.
Phil Gatchell
P.S. I am the Adjutant/Finance Officer of an American Legion Post in Heidelberg and use my color printer extensively. So I am in a bind.
Jul 17, 2009 | HP DeskJet F4280 All In One Printer InkJet
Digital signal
No read this. you may have a lawsuit. February 7, 2008
VIA CERTIFIED MAIL
RETURN RECEIPT REQUESTED
Job Lot Wholesale & Retail Stores #2
86-01 Rockaway Beach Blvd
Far Rockaway, NY 11693
Job Lot Wholesale & Retail Inc.
87-85 Parsons Blvd
Jamaica, NY 11432
Attn.: Yosef Ben-Aderet, Chairman or Chief Executive Officer
Re: File No. EB-08-NY-029
Citation No.: C20083238025
Dear Retailer:
This is an official CITATION, issued pursuant to Section 503(b)(5) of the
Communications Act of 1934, as amended ("Act"), 47 U.S.C. S: 503(b)(5), to
Job Lot Wholesale & Retail Stores #2 and Job Lot Wholesale & Retail Inc.
(collectively "Job Lot") for failure to provide appropriate Consumer Alert
disclosures on analog tuner only television receiving equipment in
violation of Section 15.117(k) of the Commission's Rules ("Rules"), 47
C.F.R. S: 15.117(k). As explained below, future violations of the
Commission's rules in this regard may subject your company to monetary
forfeitures.
On January 30, 2008, agents from the Enforcement Bureau's New York Field
Office visited Job Lot at 86-01 Rockaway Beach Blvd, Far Rockaway, NY
11693, and observed that Job Lot did not have the proper Consumer Alert
VCRs, DVD players, and similar products. For more information, call
the Federal Communications Commission at 1-888-225-5322 (TTY:
1-888-835-5322) or visit the Commission's digital television website
at: www.dtv.gov."
Accordingly, it appears that Job Lot has violated Section 15.117(k) of the
Rules by failing to place conspicuously and in close proximity to the
following equipment, in clear and conspicuous print, the required Consumer
Alert label:
Manufacturer Device Model # Number of Units
Symphonic TV WF24T5 1
Magnavox DVD/VCR MDV530VR 2
Magnavox DVD/VCR MWD2205 2
Magnavox VCR MVR450MG 1
Emerson VCR EWV404 3
FEDERAL COMMUNICATIONS COMMISSION
WASHINGTON, D.C. 20554
Nov 18, 2008 | Symphonic ST413C 13" TV
Unwanted repeat printing
There are 2 possible reasons:
  1. The last printjob remains in the COMPUTER'S memory
  2. The last prinjob remains in the PRINTERS memory
You can easy find out in witch case you are by turnig on the printer in the morning before turning on the PC.
If the page from yesterday do not print without the PC on then try reinstalling the printer (after uninstalling it - or delete it from Control Panel - Printer and Faxes). Pay attention before shutting off the PC if there are running jobs in the printer. (doubleclick the printers icon in Control Pannel - Printer and Faxes). If they are, try to delete them before shutting the pc off.
If the page do print evan without the PC turned on, than it's in the firmware and i have to admitt that i dont know exactly what the solution could be, but let me know and i'll search again.
Jan 24, 2008 | Minolta PagePro 1300W Laser Printer
Document will not delete
open side cover and then try to delete this document.
Dec 18, 2007 | Konica Minolta bizhub C250 All-In-One...
Kyocera Mita KM-2050 Printer Logo
429 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
