Go to this link and download or look at the manual. Somewhere in this manual will tell you how to increase the oven temperature. Good luck. http://www.manualslib.com/manual/247310/Panasonic-Nn-T888s.html#product-NNT888S%20-%20MICROWAVE/CONV.OVEN
go topartstown.com in the top right corner enter your model and choose the installation and operation manual there are wiring diagrams in a printable version
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
http://www.blodgett.com/convection_full.htm
Go to this web site. It has you manuals and other info on your oven. be patient and look, sometimes hard to find.
Let me know if I can help any further.
