Question about Dell 3000cn Laser Printer
Coloured dots There are dots of all four colors on any page I print in colour. When printing in black and white there are black dots only. Have done all of dell's online solution (remove, clean and shake each cartridge). Also the drum cartridge is fairly new so I don't think it is that (but i might be wrong). Any advice would be greatly appreciated.
  • Randy1980 Jun 15, 2008
    I am having the exact same problem. I have had my Dell 3000 laser printer for about three years and just replaced the color cartridges. I am getting the single black dot on black only documents and getting four dots (black , cyan, magenta and yellow) on pages in color.
    I tried removing and replacing the cartriges but it had no effect.
Maintenance - BTR Adj - Plain 1 - 5 to 8
Posted on Oct 14, 2008
What is the amount of magnetic Powder to be developed in the Fuser Section?
None. It is electrostatic attraction.
It varies from each type of laser printer.
Most printers will specify a total number of pages printed from a laser toner cartridge rather than give an actual amount of toner per page. Which I feel would be more likely to be an average value.
Due to the amount of toner being used per page varying on the number of actual pixels that are required - a black dot or a color dot. If a colour dot is required Three toner colors may be involved to get the color required. Where there is a white dot no toner is required.
It really depends on what image is being rendered onto the paper on each different page image print onto the paper.
Color photos use more toner as more of the page is color than when using black and white !
Jul 02, 2015 | Office Equipment & Supplies
I put a new hp tri colour cartridge in my printer ....when it prints off test sheets it prints in colour but when i try to print off colour documents it only prints black and white
There's an option under your print setting for color or black and white. When you select to print a window will pop up. make sure that you have the color print selected. Hope this helps
Nov 10, 2013 | HP DeskJet F4280 All In One Printer InkJet
I have message "Cartridge Error". I have established that the colour cartridge seems to be faulty. It is old and only replaced once because I do not actually need colour, use mainly black printing onl
Hi and welcome to fixya
You can print black pages with the color cartage. HOW ? just when you select the size of the paper A4 then ther is an option of colored printing or black if you have ink in the color cartage then it can be done that you can print black pages with that cartage
thanks hope that will be helpful
Dec 08, 2012 | HP Officejet 5610 All-In-One InkJet...
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Printer only printing in black and white
you might have printer set to print in black ink only check in settings if not re install printer driver then print test page if the windows logo comes out in colour and the text black everything is fine
Jul 09, 2010 | Brother DCP585cw AllInOne InkJet Printer
Printer is not printing black but in a pinkish color
Most printers use the colour cartridge to make black, instead of the black cartridge. When you go to print a black and white document, on the box where you choose the number of pages to print, click properties, and locate the colour settings. There will be two options: Colour/Black and White-with a sub option of high quality or black only. Select Black only. The printer will now only use the black ink.
Apr 14, 2010 | HP J3680 Officejet All In One Printer
I have a Lexmark 1200 printer. Colour promlems
It could be that the cartridge has become dry.
you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
Nov 03, 2009 | Lexmark Optra Color 1200 Led Printer
Solution for "I have a Epson Aculaser c1100 and four coloured dots have appeared when printing. These dots are approximately 5cms from the left side of the page and print in a small vertical group. Each...
The four coloured dots are what is known in the trade as "Traffic Lights". They happen when the photocuductor (PCU) drum gets scratched. If you do a black only print you will only get a black dot, if you do a print with some colour in it you will get all four dots repeated at 150.41mm (PCU drum circumference) intervals. The best answer would be to replace the PCU but it is expensive. The alternative is to take out the PCU, find the scratch and try to polish it out with a very soft cloth. This will only work on the lightest of scratches. Be very careful not to scratch the drum further and avoid shining any bright light on it as it will damage the photo-sensitive surface (normal ambient light is OK).
Apr 11, 2009 | Epson Aculaser C1100 Printer
Printing in black and white
the only way i got mine printing was to replace the colour ink! sorry
Mar 12, 2008 | Epson Stylus C46 InkJet Printer
Dell 3000cn Laser Printer Logo
207 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
