Maxtor 500g network drive
Hi i have a draytek router connected to a netgear pro switch which is connected to a safecom router (dhcp disabled) the network drive is connected to the safecom i can access the network drive fine via wireless but when i connect a computer via ethernet on the safecom i loose network connections the maxtor drive ethernet light keeps flashing and the safecom port lights keep blinking on and off if i remove the drive everything is fine and if i plug the drive back and remove the computer everything is fine. all ethernet cable are straight through and the netgear pro switch is auto sensing no crossover cables needed. its odd that thw wireless side works but not the wired side
  • R6NETWORK Feb 18, 2008
    hi the switch is auto sensing so no cross over cables are needed. but i have tried to conect the maxtor network drive directly to the draytek vigor 2800 router and although the router lights show the drive as being connected and the drive network light shows its connected on the router web page the dive is not listed as an attached client and i can't see it anywhere on the network. i think the firewall on the router must be stopping it i dont know how to open port 4301 on the routers web interface for local lan clients only as i dont want to open this port to the wan. the reson i think the firewall is blocking is that i can see all the other attached clients in the dhpc page with their mac addresses i have not enabled mac bind so that can't be the problem and i have tried a crossover cable still no drive yet it will work on the safecom router. i know the firewal on the draytek vigor 2800 is far more robust so it could be the cause of my problems any ideas
    thank you
    Scholar:
  • 70 Answers
Describe to me exactly how you are set-up. Include the IP addresses of each device and exactly what ports are being used on each device. Could like an IP mistake or in some cases an X-over cable is still required IF your switch does not have does not have a x-o button on it. But that depends how things are connected. These are the 2 most likely but need the above info to diagnose.
Jeff
Posted on Feb 16, 2008
  • Jeff Sapper
    Jeff Sapper Feb 18, 2008
    Do you have your users guide?
    Read through the Firewall section, page 42 et. I would suggest disabling ALL filters and see if it works. If it does, enable one filter at a time until you hit the one that prevents network detention.
    Let me know how it turns out or contact again if you don't understand something.
    Also understand about autosense. It has to do with the bandwidth (what everyone calls speed). It will sense if its 10/100 connection or duplex mode (duplex mode is like a walkie talky, only one person can talk at a time -half duplex- or both can talk at once-full duplex)...
    Jeff
I do not want wireless router to assign ip addresses for lan
not sure if you are doing it right
your wireless router has 2 "sides" one is it's upload, it's wan network and that is where you should set DHCP - so that the router itself gets an ip from your LAN
other side is behind your wireless router and there DHCP should also be off. it would be best if you could put your router in bridged mode - just to extend your network over WIFI
Mar 08, 2012 | ASUS WL-500g Wireless-G Router + WL-100gE...
Tip
Configuration of NETGEAR router as Access Point: The below steps illustrates the...
The below steps illustrates the usage of router's like WGR614, WGT624, WPN824 as an access point to extend the wireless network in your location. The only required setup is that you should have a DHCP server running on your network ( be it your modem or a different router).
1. Connect a computer directly to NETGEAR router on any of the four LAN ports.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.1.1 to a free IP of your existing DHCP network.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the existing router/modem to the Lan port of the NETGEAR router.
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to NETGEAR router or wirelessly as per your requirement.
on Mar 18, 2010 | NetGear WGR614 Wireless Router
I am trying to install a Netgear router after my switch. I end up having no internet on some of the computers connected to the hub and none on the router. If I configure the router as a dhcp client...
You'll want to configure your router as a dhcp server. Connect the switch to your router's lan port. Connect the remaining devices to a port on the switch. Your wireless access point should have it's dhcp server disabled. You can only have one dhcp server per network. The wireless can get it's address from the router's dhcp and the wireless client devices will get their ip address from the router, as well. If your wireless access point is a router with a wan/broadband port and some switch ports you will want to make sure that you are connecting to your Asus switch via one of the switch ports.
Be sure that your client devices are configured to get their ip address via dhcp and you should be surfing the interweb in no time flat.
Oct 21, 2010 | ASUS GX1008B 10100Mbps Desktop Unmanaged...
How fix wireless drop. why does my netgear wireless router seem to drop or just no connection to my laptop? I'm currently using this model NETGEAR- RangeMax Dual-Band Wireless-N Router with 4-Port...
Try turn OFF DHCP, START>>RUN>>service,msc enter, scroll down to DHCP, set to OFF & Disabled, also further down Windows Zero configuration, again OFF & Disabled.. reboot,try that.
Feb 28, 2010 | NetGear RangeMax WPN824 Router
Assus WL-500gP router hangs
I had the same problem and found the solution here (last post):
http://wl500g.info/showthread.php?t=11077
Short answer: "the power supply is faulty"
Jun 28, 2009 | ASUS WL-500g Premium Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Aquiring Network Connection over and over. RAWR
How many DHCP devices are there on the network?
There should be only one. Try disabling the DHCP in your device, then your neighbours router should issue IP addresses and all will be ok.
Apr 26, 2009 | NetGear WGR614 Wireless Router
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Netgear FS105 Switch is not fowarding ports properly.
Does your modem have a built in router or do you have a router in your network. The switch needs no changes that's all it is a switch it will allow computers to talk and share fine, if you want to use it for internet you will need to connect it to a router first or use one of your computers as the router and let it share the connection. since you disabled DHCP on your router I am assuming you have a router. all you need is to connect the switch to the router, the connect the computers to the switch and all should work.
Dec 24, 2007 | NetGear FS105 5x10/100 Mbps Networking...
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
