Question about Canon PowerShot G5 Digital Camera
It wont turn on
I have a canon powershot G5. I was taking photos and it just shut off by itself. now it wont turn on and when I charged it, the charge indicator on the camera doesnt even appear. can anyone help? thanks
  • 5 more comments
  • burbs Mar 20, 2008
    Same problem. Went to China three weeks ago.... could not use with any of the batteries (I use separate charger) or plugged. Just no indicators at all. completely dead.
  • eiji Apr 08, 2008
    I have the same problem. MInutes ago, it worked fine, then suddenly stopped working without any indication. Went home and tried spare battery and even AC adapter - But nothing powers up G5. Started taking off covers to see anything obvious right now...
  • renee500 Apr 26, 2008
    My powershot G5 won't power on. I've bought new batteries nothing. It runs fine if I use the charger as the power suplly?
    Help
  • Anonymous May 05, 2008
    I am having the same problem! Bought a new battery. Is anyone having any luck with trying a new charger? Or does the camera need repair?
  • Tess K Jun 25, 2008
    Same problem. I can't even get any power via the adaptor. Do I need a new battery?
    Thanks, TK
  • Tjeld Jul 22, 2008
    I have the same problem, camera would suddenly not turn on. I have two good batteries and a separate charger, so I can eliminate battery failure. However, when I remove the flash card, the camera reacts to pressing the power button with displaying a "low battery" message for a couple of seconds. I've also tried different flash cards, but there's no response as long as there is a card in the camera. So it seems like a hardware or firmware problem to me.
  • camerathomas Mar 10, 2009
    My camera has done the same thing. I had completely charged it last Saturday morning. When I went to use it, it won't do anything. It won't turn on at all. It doesn't respond to anything I try.
Hello
First, you must be certain that your battery pack is still good.
You have to clean all connecting point (between the camera and the batterry) with a dry clean cloth inside the battery pack compartment.
Another think to check, is the date and time battery (dime size battery located inside the battery pack compartment) to remove it, slide the battery case out and change it. Since the battery is install at the factory, it verry possible that there is no more power. At the end of your owner manual, you will find, before troubleshooting section, the way to remove it, it verry easy, no force need it.
A deffective flash card can also cause the problem. Remove also the flash card and replace it by a new one or another one that you have.
When the battery is fully charge, install it along whith the new time and date battery. Leave the camera alone for a couple of hour in order to let the board get some refresment. Try to put it on, if it not work, slide in and out the battery, couple of time, close the compartment and try again.
In many cases, the camera will start and you will have to put the time and date, if the battery (time and date) was warn out. Make sure that your screen is on. You ready to go. :)
Posted on Aug 16, 2009
Try to check if your charger in the first place can still charge your battery. It could be the reason why there is no "charging light" indicator.
Posted on Mar 10, 2008
It wont take a picture with the flash, i have to turn off the flash or it says charging flash?
This message truely indicates that the flash is charging however you couldn't get it to flash because the bulb needs to be replaced.
Hope helps.
Apr 15, 2011 | Canon Powershot A2000 IS Digital Camera
I have a Canon G5 and am on my third set of rechargeable batteries (I bought an extra Canon rechargeable battery when I purchased the camera and then 2 Canon brand replacement batteries when the first 2...
Thank you for such a detailed description, wishing others would take your lead. To the problem camera designated batteries (other then AA rechargeable) have always been a bit of a sore spot for me because the user is compelled to purchase a specific battery. As much as I prefer the name brand accessories for the camera there come a point where you just gotta venture forth with third party accessories. There is nothing wrong with using an "off" brand in fact what I've found is that is some cases they are a better battery. Again back to the problem. I grasping thoughts on how to word this but, here goes. As much as the manufactures would like you to believe that these batteries do not form a memory they do. Also the battery can trick you into thinking it's fully charged when in fact even though the charge light is saying completed it's only got about 1/3 charge. I've worked with Canon's BP 511 and now the "new" BP 511A for many years The BP511A or equivalent is the better battery. What needs to be done is to drain those batteries down until they stop, let it cool don't take it from the camera to the charger. Time the battery when you put it on the charger, meaning not to the second but what you would "normally" do is plug the battery into the charger and leave it right. Well what's possibly happening is that within ten minute the ready light is coming on, (something stupid going on in the battery) So check the battery stat of charge after say 15 minutes and if it says it ready (drum roll please) remove the battery unplug the charger for a few seconds and place the battery charger back onto the wall outlet and plug the battery back into the charger and look at your watch again. I've had to do this as much as three times until the thing would get the idea it was to take a charge "normally" about 2 hours will bring it back up. There is no device I've found to completely drain one of these batteries so over a period of time in your case one year the batteries begin this fit. I've since replaced the BP511 for the better BP511A's or equivalent. I'm not pointing a finger because myself and staff do the same thing and pull the battery before going to a shoot if it's showing partial discharge and the thing gets put onto charge and we start this cycle all over again. Be careful of the charger as well meaning don't just disconnect the battery and put it back on charge when it's going the cycle thing disconnect the charger from its power source as well because it holds a memory for a few seconds and will just shut off in a few moments if you don't.
Long story but I've been doing this now for 9 years since the dawn of Canon's 30D Cheers
Jan 16, 2011 | Canon PowerShot G5 Digital Camera
Camera will not turn on and battery indicator displays battery is fully charged. Canon Powershot G6
You need to clean the battery contacts with a Q-Tip dampened in rubbing alcohol inside the battery compartment. Also clean the battery itself and the charger. Thanks, Dana
Sep 30, 2009 | Canon PowerShot G6 Digital Camera
Canon SD790IS shuts off when reviewing pictures
Your photo card may be corrupt. Try replacing the SD card with another one. If it works, copy all your photos off the old card, then format it.
Jul 19, 2009 | Canon PowerShot SD790 IS/ IXUS 90 IS...
It wont turn on i tried charging the battery to see if it was dead but it wasnt the battery it wont turn on!
Are you sure it is dead or is it simply that liveview is not showing? A friend of mine thought hers was dead the other week but liveview was turned off. Try taking a few photos and see if it actually takes them?
Jun 11, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Canon G9 blinking green indicator light
Go to this site and try emailing them: www.camerasandparts.com They just service the Canon Powershot cameras and they are wonderful for help with these. They do excellent work and are about half the price of Canon. Hope that helps, best of luck with the problem.
Feb 28, 2009 | Canon PowerShot G9 Digital Camera
Charged battery for first time
The battery does not work at all/the charger was shut down.
Dec 30, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
Dec 16, 2007 | Canon PowerShot G5 Digital Camera
Canon G5 Lens error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 07, 2007 | Canon PowerShot G5 Digital Camera
Canon PowerShot G5 Digital Camera Logo
564 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
