Question about Baby Gear
Instructions needed for 3M adhesive (08224)
How can I find how to apply this 3M adhevsive product?
AutoMix N. 08224
I can not find any directions/users guide on the package nor here.
Thank you in advance,
Bob
Dania Beach, FL
Mmatch@Hotmail.com
  • Mmatch Feb 17, 2008
    Went to that site but found no instructions there, either.
  • Mmatch Feb 18, 2008
    THanks, that's what I did.
    Thanks for your quick suggestion.
    But I had hoped I might find someone via this site more experieced/knowledgeable with this product ... like I am now!
    I'd prefer not to have to "re-invent the wheel".
    E.g.
    1.) The product does have minimal directions ... if you know to peel off the label and read the fine print underneath.
    2. Still wonder the effect/importance of the (optional?) "accelerator" over time, dependence on timing, locations of application, etc.
    3) At least, I have since learned that this product is available for sale WITHOUT the "accelerator" which would imply successful curing (however slower) but uncertain how much slower, stronger, etc.
    Bob
  • 50 Answers
Try 3m web site 3m.co.uk might help you
Posted on Feb 16, 2008
  • andrew gobby
    andrew gobby Feb 17, 2008
    what is ths product glue of some sort if it is try in a well vented area glueing a test togther what have you to lose
  • andrew gobby
    andrew gobby Feb 18, 2008
    thanks hope you had sucess andy
How do I download the manual?
There appears to be no manual for this product, only the "User Guide" that was included in the packaging. If you've misplaced it you might be able to contact Antec directly - but they do not offer downloads from their website.
Nov 17, 2015 | Antec LifeBar 10 Portable Battery Charger
For installing trunk lid weatherstrip on a 1994 Cadillac Concours DeVille, what is the best weatherstrip adhesive to use, approximately how many ounces of the adhesive are needed, and what is the best way...
You are reading into it too far !....... put it (nozzle) into groove and squeeze 3M weatherstrip adhesive (black) for a thin coat all the way around seal then carefully start putting it on, making sure you don't stretch it installing it....otherwise you will have a bunched up spot when you end . and will have to try and work it out pushing outward all the way around to get slack out of it. DO NOT CUT IT !!! IT'S MADE TO FIT TRUNK AND MAKE SURE IT'S NOT UPSIDE DOWN !!!!
Dec 28, 2012 | Cars & Trucks
Need a new regulator kit part number 9204
http://www.hotmelt.com/products/3m-9204-pg-regulator-kit
Mar 02, 2011 | 3M Polygun Ii Glue Gun Adhesive Applicator
Material has become detached need to remove and re-cover
headliner detached?...3M makes a great product to put the material bad on...super 77 adhesive or take to a body shop and have them replace it,,,DO NOT SMOKE WITH THAT 77 ADHESIVE..EXTREMELY FLAMMABLE!!!!!!!!
Jan 24, 2011 | Jaguar S-Type Cars & Trucks
What type of adhesive will bond to the plastic in the front bumber/shroud of an 05 Highlander?
3M weatherstrip adhesive. Comes in several colors. Black is probably the color for you. Once the bead of glue is applied, affix pieces to be glued then remove for a few seconds to allow the adhesive to "wick". then press pieces together and hold until glue sets up. Good luck!
Dec 03, 2009 | 2005 Toyota Highlander
Ge tbx18ja there is water coming from BETWEEN the back of the refridgerater and the black elbow plumbing that connects to the hose that runs down to the pan...
I would suggest pulling the black elbow out , and blowing thru it , to clear any possible obstruction . Then , use an adhesive , like super glue or a 3m adhesive product , around the black spout . This spout , inserts into the drain pan outlet tube . After applying the adhesive , reinstall the black spout into the tube , and use duct tape to hold it securely , against the refrig body .
Nov 19, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Sand paper keeps slipping help
I don't know what type of sander you are speaking about it just says generic ALL PORTER CABLE SANDERS. You got to be a little more specific. If it is a disk sander use 3M disk adhesive. It is a contact cement. spread some on the rubber backing disk with your hand, let dry then apply the sanding disk. After the disk is clogged, peel it off and apply another disk. when the adhesive won't hold anymore disks, re-apply the adhesive.
Oct 23, 2009 | Porter Cable Tools & Hardware - Others
Baby Gear Logo
170 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
