Back to:
Tags:
Panasonic Workio DP-4530 Grayscale Copier
Panasonic workio dp-4530
posted by 654123 on Feb 15, 2008
Good morning i have one problem with this machine, when turn on with the front cover open the machine on but when close front cover it's turn off. I need your help .
Apreciated that thanks a lot
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 16, 2008
Inappropriate (40)
canonman1
Rank:Guru Guru
Rating: 88%, 54 votes
the power switch going off is a saftey function because when the cover is open the AC line inside the machine is open circuit.
When you close the door you effectivly close the circuit however if the machine still detects an open circuit the machine trips the power switch as a safty precaution.
Possable causes...
FAULTY DOOR INTERLOCK
FUSER UNIT lamps/fuses
Thank You
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on panasonic workio dp-4530:
I don't want to Accept this solution
Can you Help with these Copiers problems?
Copiers
SIR, when i am using ADF to photocopy LGL size document...
I also have a dp 4520 error code E03-60 with low page...
Can tell me what the issue is and how a novice can solve...
Copiers
I have a Risograph RZ220 with the code d--13 --9. The...
Paper jams at finisher when making multiple copies. Using...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
