Question about SATO M-8490Se Thermal Label Printer Print Engine - P/N W08491811
Sato m 8490se label offset position
How can I change the amount of feed , my label doesnt come out far enough and sticks to the next label when tamping
  • 54 Answers
If on an applicator, you can change the coarse off set in the printer settings, there is also a pot inside the door by the ribbon that you can adjust + - 3mm
Posted on Feb 25, 2009
Cutting position is NG
It could be just as simple as loosen screw...
I have been days trying to figure out with mine and finally was just a loose screwe on the side. Check out
Apr 04, 2014 | SATO CL612E Printer
The printer is new. When you press the feed button,it does dot feed 1 label. What do I need to do to correct that?
First download a driver ans install it.
Second program your label size.
Third Select the correct settings (Detection, protocol etc..)
Print a label.
Now when you press feed you'll get a label
Aug 15, 2011 | SATO CL608e Thermal Label Printer
Sato cl408e - printing over perforations. I tried turning the Pitch(all the way to the right) and Offset(all the way to the left), and this helped a little, but still not right. Because of this, when the...
Reset printer sensor threshold setting.
Turn on printer whilst holding down line key untill printer beeps.
Use feed key to step to Gap in display.
Load label plus backing under sensor and not volts reading.
remove labels and place backing only under sensor and note volts reading.
use following formula
High reading + Low reading / 0.5 = Value to use
e.g 2.8 + 1.4 / 0.5 = 2.1.
use result to change value of input using line key once set press feed key to set.
To change label start position use the pitch menu.
Jun 02, 2011 | SATO CL408e Thermal Printer
Hi, Sato CL408e, it starts printing between the labels. The feed is off by about 0.5cm. Any idea on how I can adgust that?
1) Try to calibrate the printer.
Else
do factory reset ( Press LINE and FEED At same time and switch on the printer.
Else
Change the potentiometer offset (Pitch,print) settings in the front panel.
Rgds
Mohan
Jan 21, 2011 | SATO CL408e Thermal Printer
The printer will print one label correctly, then feed out a blank one. when the next label is printed, the printer reverse feeds the blank label into the printer to print the next one, but not far enough...
This sounds like a size issue, meaning that your label has too many lines and that kicks to the "next page".
Look for too many line items on first label.
Oct 06, 2010 | Zebra Z4M Printer
What is dip stick setting for dhcp Sato cl412e with ethernet card
You must use the provided software to change the settings. It looks for the printer by the MAC address
Aug 17, 2009 | SATO Cl412e Label Printer
Sato 408E problem
Using direct thermal labels it can dirt the printhead and platen roller, you must clean them with isopropyl alcohol and a flannel. Also adjust the darkness to less value to best print.
Roberto Martinez
Jun 29, 2009 | SATO CL408e Thermal Printer
Trying to set the offset on Datamax Prodigy Printer
Add the OFFSET command (Oxxxx) command to beginning of the data. A value of around 0700 usually works.
The prodigy+ does not have any other facility for setting the tear-off position, nor is the effect of the O command persistent.
I don't know where you're seeing that offset value since the printer cannot report it. If it's in your printer driver, then try adjusting the value in the driver itself.
Steve
Jan 07, 2008 | Epson Printer
Advances ticket too far after printing.
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Nov 05, 2007 | Zebra Eltron TLP 2742 Thermal Label...
290 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Howard
Howard
WTF Chuck.....
WTF Chuck.....
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
