Question about HP DeskJet 6122 InkJet Printer
Paper jam Can you please give advice on how to clear a paper jam? When I switch on it seems to collect one sheet and not feed it through. Also, I think there may be part of another sheet stuck in the works. The orange arrow on the right keeps flashing - does that just mean it recognises a problem? Thanks for any advice you can give. Regards Seton McNeill
Remove the back cover and look if there's any paper stuck in the feeding mechanism.
Posted on Feb 15, 2008
PAPER JAM
When the paper goes it on the inside of the printer grabs both side which what feeds it through, if it is not tight enough will cause paper jams, open it back up and check the roller to see if it can be adjusted if it cant then you will need to buy a new one, this usualy happens when it has had too many paper jams forcing the gap to increase in size and not allow the collection of one but many, on single sheets of paper the gap wont be small enough to collect 1 sheet anymore.
Aug 18, 2012 | Dell 810 All-In-One InkJet Printer
Tip
Steps to clear paper jam.
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
E-04 paper jam
Hi, my printer did the same and following the instruction of turning it of and clearing any jam didn't work. In the end I forced a sheet of paper into the printer intake at the rear of the machine and turned it off. The printer then took the sheet in about a third of the way. When I switched the printer on the sheet was then drawn through and out the front as if it were printed on. I think the printer has some sensors which must detect a sheet passing through them for it to reset. Hope this works.
Sep 23, 2008 | Epson Stylus DX6050 All-In-One InkJet...
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Carriage Jam
If you are certain the thaere is no 'jam feed a piece of paper
That is have a sheet line up to go and clear the service button[Is there one on this model?]
Then switch off and leave for 10 minutes.
Switch on and do a head clean.
Come back with the result..
Dec 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP DeskJet 6122 InkJet Printer Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
