Question about Sony MHC-NX3AV Shelf System
No radio My Sony started to buzz in Pro-logic mode & now for some reason the radio will not work, any clues? all the wires are in the right place.
  • 1 more comment
  • omegamen Jun 15, 2008
    Exactly the same problem.... wish I could get it repaired... 15th June 2008
  • surprisingly Nov 19, 2008
    I have the same problem, noticed it yesterday. When I switch on the 5.1 speakers, the buzzing starts. It happens either by using the Pro-Logic mode, or by using the DVD 5.1 mode.
    I opened up the system (warranty is wayyy out of date - bought it in Feb 2000) and found out that the side board was cracked at the point it is screwed to the bottom panel. Now this may or may not cause the problem in my case. It is a small crack and also no routes appear to be broken in the IC. However, it might function as a ground connection and be needed.
  • Anonymous May 03, 2009
    Same problem - buzzing in the rear three channels in any mode where the rear speakers are enabled. Haven't taken it apart yet, but I am handy with a soldering iron, so will try the suggested cap kit.
HI,
Here is the solution for your problem.
You have to look at the 10volt B+ on the mainboard.
This voltage goes to the tuner en other ic's.
You have to replace the next capacitors:
C921 470/25v, C922 1000/35v, C920 1000/16v, C924 47/16 and
C927 100/16v.
The best to replace them witch 105 degrees capacitors, then the problem don't come back again.
Good luck
Ben Bierhuis
ben@dbinet.nl
Posted on Jan 14, 2009
  • Jose Luis Perez Jun 28, 2013
    Great! It was C921. You're the boss. Thanks a lot.
    Great! It was C921, as you said. You're the boss. Thanks a lot.
I went and get the truck inspected the obd plug wouldnt read then it did the auto place said it was a loose wire then a week later my signal lights buzzed and door will buzz and the key is out of the...
first check all the wiring leading up to the "repaired" obd plug it may be there seeing as how the problems seemed to have appeared after it was fixed. after check the wiring to the radio as that may have caused the radio to quit and may be the cause of the other problems as well.
Mar 23, 2015 | 2006 Toyota Tundra SR5 V8
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
Having problem programming Pro-94, is there a simpler book or read than the manual. It says you must load in logical channel order. how do I determine this??? Also am I correct in that you can only load...
put your scanner in manual mode.and then go to program mode and program your frequencies into your scanner.try that and see if that works.....if not it could be a problem in your Radio....
Feb 22, 2011 | Radio Shack Pro-94 Scanner
I'm going to surround sound mode, and my rear speakers are not working. I do a tone test, and they def work, but I can't get them working right?
Since you seem to be having problems with 'simulated' surround, how does ACTUAL surround material behave?
Have you tried AFD with certifiable multichannel source material to verify the surround speakers receive programmed sound??
Do the Dolby Digital or Pro Logic indicators light?
What about the other modes?
Mar 20, 2010 | Sony STR-DE475 Receiver
In radio mode, all speakers do not work
Radio will default to 2 channel stereo. You will need to use one of the soundfield processing modes to expand. Try using surround mode button to get to 6 channel or pro-logic.
Dec 29, 2009 | Sony STR-DE597 Receiver
Prima HT 8104 home theatre
in the 3D processing turn on the Pro Logic and the for the mode as well set it to pro logic.
it simulates 5.1 surround.
this is what I did and it's decent. Other way would be to run the system through a amp/receiver that supports 5.1 surround.
Mar 24, 2009 | Audio Players & Recorders
I have a sony hdx279w surround system, the center speaker is not working? I can not figure this out. I also...
you have to go to system menu and press up and down until "DEC.MODE" appears then press the right arrow press up n down again put it on "PRO LOGIC" that should work it did for me .good luck!
Mar 10, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
My 95 is way off - Freqs,Mode not working...Grrr!
mORE AND MORE POLICE AGENCIES ARE SWITCHING TO "DIGITAL TRUNKING". I CAN ONLY PICK UP PARTS OF MY LOCAL SHERIFFS STATIONS. RADIO SHACK HAS THE NEW dIGITAL TRUNKING SYSTEMS THEY COST ABOUT $500. I AM UP GRADING NOW. FOR TRUNKING ... WHEN YOU GET A ACTIVE CHANNELL KEEP HITTING THE RED TRUNK BUTTON TILL YOU SEE THE MOTOREOLA 5 NUMBEWR ID.THJEN HIT ENTER. I WANT THE NEW PROGRAMER THAT IS FAST ENOUGH TO FOLLOW DIGITAL HYPER-TRUNKING. ALL POLISE ARE GOING TO IT EVENTUALLY.
Sep 18, 2006 | Radio Shack Pro-95 Handheld Scanner
Sony MHC-NX3AV Shelf System Logo
223 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
