Question about Toshiba Satellite A105-S4004 Notebook
Right side of screen flickering (top to bottom)
I had my toshiba for about 4 years now, Everything fine but I noticed that electric cord insert to back of machine is loose. I believe this is the culprit. How can I fix this? The right side of screen is flickering alot from top to bottom.
Thanks.
  • siammurph Feb 19, 2008
    I took my laptop to a repair shop and she told me that the LCD needs to be replaced. I was mistaken about the loose power connection. It is loose but the repair gal told me that it has nothing to do with the problem.
    I can still work on my laptop and I guess I will continue to use it with the flickering. I hate to throw it away or retire it to the computer junk yard just yet,
    My Toshiba still putters away even with a missing battery, four letters missing from the key pad, and with a dvd tray that needs to be pulled out with your finger nail.
  • siammurph Feb 21, 2008
    I can't believe it. The repair gal was either incompetent or trying to rip me off. She offered me $50 bucks for my computer for parts and told me it wasn't worth it to fix it. I go on EBay to bid for a broken same model so I can use the LCD. Luckily, I was outbid because I took apart my laptop yesterday and look inside. The ribbon was fine. Today, I was doing a search for loose plug and low and behold it suggested that it is indeed the culprit! I wiggled the plug and the lines disappeared!
  • 72 Answers
Your laptop screen has a thin ribbon connecting the screen to the mainboard. after upening and closing your screem these pins sometimes breaks causeings streaks in your screen. My compaq note book has to be resoldered because of a lose connection on back for power. your gonna want to get that fixed before you fry your board. costs about 50 bucks for an hours work to get that solderd. It could be linked to your flikering issue..
Posted on Feb 16, 2008
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Jan 19, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Screen flickering
That really depends on when it flickers, does it flicker when you move the display open or closed or when you press some part of the laptop?
If it happens when you press a part of the laptop, the display cable could be loose, thats unlikely.
I recently had a similiar problem with a toshiba laptop, the screen would flicker when pressed on the bottom left side of the laptop.
I checked the wires and they where fine, in the end I seem to have fixed the issue by pressing on the top cover where the issue happens and at the same time from the bottom from the same spot, what I did on that laptop, there was a cover that I could remove so I could press directly on the mainboard, pressing directly on the mainboard with my fingers and at the same time pressing down from the top seem to have fixed the problem on that laptop.
Sep 11, 2009 | Acer Extensa 5420-5687 Notebook
White screen
The LCD display in a laptop connect to the screen via a ribbon like cable which is not very secure.
It can happen that over time that the ribbon cable become dislodged by slightly rough handling or vibrations etc. the reasons are infinite, but we arent worried about the why but the how :)
it is quite possible the display is faulty, but if you are brave place the laptopn on a rubber mat of some sort ( car floor mat ??? ), on a table, place a bright lamp close by and open the casing on the bottom first, then turn it and remove the keyboard, look for a ribbon cable coming from the screen that inserts onto the main board. it should be easy to see.
If you arent prepared for this, ask someone you know to do this for you... the cable simply pushes into the slot where it belongs,
this abov e is at your own risk though, be careful of static since this could damage the components ( hence the rubber mat )....
Nov 21, 2008 | Toshiba Satellite M100 Notebook
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Hitachi 51f500(flicker+warp)
Most likely bad convergence IC's! Location numbers should be IK04 and IK05. Generic numbers STK392-110.
Jan 23, 2007 | Hitachi 51F500 51" Rear Projection...
Flickering on black screen or dark areas of a screen
The moving might have created a loose conection,the sets age tell me there are possible other overheated areas that need to be resoldered to prevent other symptoms,If you are familiar with tv service you can check the conections in the output transformer area,he is responsible for generating the high voltage that lights up the 3 picture tubes,before the Hight volatege gets to the pix tubes there is a High volage distribution box that separetes the voltage for each tube,check it and make sure is not degraded,you need to be very careful when dealing with these parts,there is a lot of volatge in that areas,If you are not familiar with tv service be safe and call for assistance froma servicer.
Oct 11, 2006 | Toshiba 42H81 42" Rear Projection...
Flickering Lines
I recommend you call a shop and ask them how much it will be to replace the Convergence amps STK-392-110(2are in the set) 99%shure thats your Problem Good Luck Walter Grzybowski
Sep 24, 2006 | Toshiba 50H82 50" Rear Projection...
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
