Question about Panasonic KX-T7730 Corded Phone
Outside Line Button.
Hi there i hope you can help me.
My problem is that im using the KX-T7730 in a phone system and the first 3 outside line buttons are for calls but i accidently programmed a number to the first line. Now i cannot use this line for making calls or receiving, but all the other phones in the system can.
Any help would be great.
cheers
  • 3 more comments
  • steve0 Feb 15, 2008
    sorry i forgot to add i wish to delete the number saved to the outside line, but the manual only tells me how to add numbers not delete.
    Thanks
  • steve0 Feb 17, 2008
    Thanks for the info Priority1, i managed to solve the problem by trying what you said. It was outside line 1 which i had the problem with so i just went through the procedure as if i wanted to program a number, and pressed zero and then stored it, which seems to have deleted the previous number and freed up that line for me to now dial out from.
    Thanks for your help.
  • Anonymous Feb 26, 2008
    I had sort of the same problem. I got my lines back but now they don't ring. They lite up when a call comes in but don't ring. Just on the handset that I was changing some stuff on.
  • ck9504 Feb 29, 2008
    I've outside line 1 to 4 and program speedial to line 2. Now i left with 3 co line . How to get back my co line dor line 2 . My panasonic phone KX-T7730
    Thanks
  • Anonymous Jul 15, 2008
    Good Day..
    I'm having the same problem with Steve..worst is..i don't exactly what button i pressed that caused the phone to be unuseful for outgoing calls..
    i was trying to look it up on the manual but it's not helping me..
    i need the program code or how to exactly make the number 9 the line for outgoing calls again..or in my phone's case, it's the last button that has been programmed for the outgoing calls..when i pick up the handset, it says "CO not assigned"..
    please help me how to program it again..
    Novelist:
  • 201 Answers
I doubt you would be looking to "delete" the number. Instead you need to program that button to be a line button again and that will in effect delete the quick-dial you programmed. I'm not sure which phone system you have your phone connected to (you could have one of several different Panasonic systems) but programming the button for a line should be somewhat similar to programming it for speed-dial.
Does the manual you have cover any other programming options for buttons?
It's a long shot but some systems I am familiar with you can just push the same button again instead of the number. So for example if this was the line3 button, program similarly as you did before but at the step where you dialed the number, just press the line3 button.
If you're still stuck, let me know which Panasonic phone systm you have so I can look up more detail (the system is not a phone)
Posted on Feb 16, 2008
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Hi , i have a problem with my KX-T7730 : in brief , when i press the line access code which is the " 9 key" , it gives me wrong CO . so i want to change the program and set it to my desire CO...
    So many options. Why are you dialing "9" for an outside line? You can just press a button assigned to the line you want.
    Since a 7730 works on up to 18 different Pana systems, there's no telling what you have, but you can assign a specific line to a button, a group to a button, program the system to not pick vacant lines, or dial the direct line 8x or 8xx access code. There's an outside chance that ARS (automatic route selection) is enabled and the "9" doesn't even give you an outside line in the first place.
    Which is yours?
    Carl
    Aug 28, 2011 | Panasonic KX-T7730 Corded Phone
    Panasonic kx-t7730
    Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
    PLEASE vote if this was helpful
    Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
    KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
    3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
    4. Press AUTO DIAL / STORE to save your changes.
    5. Press PROGRAM to exit program mode and you are done.
    Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
    I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
    The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
    The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
    In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
    System speed dials requrie access to system program 001.
    If this does not work on your system, please comment back with your actual system model number.
    Carl
    Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
    Automatic transfer to a mobile phone number
    This question came up before and it works if you have a TA-824 as the system. http://www.fixya.com/support/t3120724-forward_calls_outside_number
    The key is that you go to the intercom and dial 9 to get an outside line. If you get a line, you don't have to program 400 to disable the unused lines. After that, you enable outside line transfer, change the time for longer than 10 minutes if you need to, and dial the 7139 phone number # forwarding code.
    Hope this helps. If you're using a different system and it doesn't, post back as a comment with your phone system model number.
    Carl
    Oct 18, 2009 | Panasonic KX-T7730 Corded Phone
    Programing outside (CO) line button
    press program button then press the flexible where you want program the CO line then press 0, here u can select which CO line need to be program.
    Ali
    Sep 08, 2009 | Panasonic KX-T7730 Corded Phone
    We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
    Panasonic KX t7730 call forwarding function to external party:
    If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
    If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
    lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
    Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
    Panasonic Kx-T123230 extension to ring
    hope this help...
    with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
    Feb 06, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    256 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
