Question about Whirlpool EL7ATRR Refrigerator
Thremostat problem thermostat not working inside is freezing up ,how do I change this
  • 4 more comments
  • bartyarmy Feb 18, 2008
    Thank you I might have given you the wrong serial number, its a whirlpool larder fridge ,on the rh side when you open the door is the light and thermostat unit . one screw on the electrical trunking that goes to the back I have undone that and the light/thermostat can be pushed forward then out there is a thermo couple going in to the skin .but that is it.!!!!! I can'nt seem to go any further help please
    what do i do with the electrics that come along the trunking to the light /themostat and how do you take them apart .thank this is getting interesting how to do it
  • bartyarmy Feb 19, 2008
    this is looking in the button on the front is the door switch hope this helps front viewshowing the trunking and screw
    yes the knob comes off ,I undid the small screw and managed to push the housing back a couple of mm then out but thats it i cannot see how it attached ,the tube comes out of the housing and into the side panel .do you need photos of this .thanks is this helping
  • bartyarmy Feb 20, 2008
    I haven't ,I've just pulled it off while still connected to see whats behind the tube goes into a hole about a inch /25mm dia .Because I didn't want to do any damaage I left this alone .I could not see any way of getting "in the unit where the dial came off and the fridge light .Have you changed one of these before ?
  • bartyarmy Mar 06, 2008
    Hi sorry i didn't get back to you I will try to get some photos on monday for you to have a look at the problem thank for being patience
    Scholar:
  • 90 Answers
Most panels pop into place. You need to find the one panel that overlaps all others and start prying them off there. Some only need the panel holding the thermostat taken out. Some you pull the control knob off and there is a screw under that holds the control in place. There is a long capillary tube that must be handled carefully to not bend to sharply. Braking it will make it inoperable. The tube hold a charge of nitrogen gas, if lost causes it to not respond to temp changes..... If you get to it only take it out far enough to pull one of the electrical wire off and see if this stops the unit from running to confirm it as bad...
Posted on Feb 15, 2008
  • 3 more comments
  • Timothy Smith Feb 18, 2008
    Is it the capillary tube on the thermostat that is going into the skin? If so sometimes it will be into a larger tube that holds it next to the freezer lining. With age it has some amount of corrosion and does not pull out easily. Is it possible to use a small mirror and push into the opening to see if it does go into a tube? If you are sure the thermostat is bad, then you should not be worried about damaging the cap/thermocouple tube and just real put some pressure on it to get it out. Maybe spraying a lube of some type will help, hopefully one that won't leave a heavy odor. Putting the new one back in will be much easier...
  • Timothy Smith Feb 19, 2008
    I may need some pictures here to see what you see...
    Will the knob pull off? It should and then you should be able to see how it is held in the housing. The plastic cover going back to the back of the freezer will most likely have ears that snap into the side. Try squeezing the sides in and gently pulling out starting nearest the light to see if this works. Not sure you will need to go that far without seeing more. It may just need pulled toward the front once the screw is out and the thermostat/light is out.
  • Timothy Smith Feb 20, 2008
    yes pics help alot...how long is the tube you have out?
  • Timothy Smith Feb 21, 2008
    I can't say that I have this exact one, but several similar. With pics of the unit with knob off and views from the back I should be able to guide you along. This would be so much easier in person........
Change a thermostat on my fridge
Hello, I think the freezing problem could be a bimetallic, this device is develop to initiate the defrost cycle into the refrigerator, if it doesn´t work properly, ice will be everywhere. The thermostat just controls the inside refrigerator temperature. I hope you will solve this problem checking this particular element.
Nov 27, 2014 | Refrigerators
Change thermostat
drain the radiator- follow the top hose to the motor-where it connects to the motor should be a hose clamp and the thermostat housing-undo the bolts -clean off the old gasket and take the old thermostat with you to the auto parts store to match it up -be sure to pick up 2 gallons of antifreeze and a gasket with the new thremostat -don't reuse your antifreeze -it becomes corrosive when it gets old- bolt in new thermostat-be sure it goes in the way the old one came out- fill up the antifreeze and you'll be golden -cheers Denny
Nov 16, 2013 | 1995 Geo Tracker
How do I get the Thremostat housing off my 1992 ford Ranger XLT 2.3
To change that thermostat you need to follow the top radiator hose to the motor from the radiator. It will lead to the thermostat housing on the block. The housing will be anchored with (2) bolts to the block (I think). Take the housing off and the thermostat is housed inside.you will have to replace it with a manufactured suggested thermo(probably 180* or 200 degree thermo).
Jan 29, 2011 | 1992 Ford Ranger
I have a 2006 chrysler 300 3.5 where is the thermostat located at?
Right in the front of the engine,on the top you are going to see the radiator hose connected to the part where the thermostat is inside.
Nov 11, 2010 | 2005 Chrysler 300
Where is the thremostat located
In BMW 328 To locate the thermostat follow the hose from the right side of the radiator to the motor at that connection there is thermostat.There should be 3 bolts which you will have to remove to take off the thermostat. In BMW 328i The thermostat is located behind the viscous fan and approx 9inches above the center of the fan. The viscous fan drives the water pump and the thermostat housing is just above the water pump at the front of the engine. The thermostat is a one piece unit and is a bit expensive £55 at dealers £42 independent. You will need to remove the viscous fan to get at it there are special spanners for this and its a 30mm socket left hand thread ( screws off clockwise). Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 1997 BMW 328
The freezer temp is unregulated. At times the inside drips water and then freezes - leaving large chunks of ice and stalagtites.
You have a bad thermostat . The piece , the temp adjustment knob is on . When the weather changes , the barometric pressure changes , and sometimes , causes the fluid inside the thermostat tube , to separate . When the fluid separates , air bubbles get in between the fluid section , causing the thermostat to either work erratically , and sometimes , not at all .
Nov 05, 2009 | Refrigerators
Follow the top radiator hose to the engine, that hose is connected to the thermostat housing. The thermostat is inside that housing.
Oct 18, 2009 | 2005 Dodge Magnum
Thremostat
The coolant thermostat is mounted on the engine, see part 16 on the following diagram:
Do not forget to rate the support given.
Thanks.
Feb 27, 2009 | 1984 Peugeot 604
Whirlpool EL7ATRR Refrigerator Logo
125 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
