Question about Averatec 3200 Notebook
Battery problem... i got a virus problem and my laptop was reconfigured. after that, i used the battery calibration but right after it started, my laptop suddenly turned off. the same thing happens when i did it again. it was on ac power and has 42% remaining in the battery when i used the battery calibration. now, my laptop cannot be turned on by battery alone. when on ac power, my laptop can be turned on but the battery always reads 0%. is this software or battery problem?
  • Averatec Master
  • 19,396 Answers
Sounds like an hardware problem. The battery charger does not depend from the operative system, and is working even when the computer is turned off and connected to power socket. Leave your laptop off and connected to power overnight. If the battery charge is still zero then you probably need to get a new or tested-second-hand battery.
hope this helps
Posted on Feb 15, 2008
COMPUTER LOCKED BY VIRUS, HOW TO OPEN IT
Hello my advice to you, is to visit a computer repair shop, and let them remove the virus for you.
You can try to install this program, in failsafe mode:
http://www.malwarebytes.org/products/malwarebytes_free/
By pressing F8 when booting.
And run the program when installed.
The virus will probably don`t let you install anything, but you can try to open msconfig, by typing msconfig in start and run, and disable suspicious running programs in the start selection.
This will prevent the program to start next time you reboot.
If you have succes with this, run malwarebytes when you have installed the program.
Good luck
Apr 22, 2013 | Acer Aspire One PC Notebook
601 error message
Hello.
I am sorry that you are experiencing this error message. It generally indicates that your measured storage capacity in your primary battery is less than 25%. What this means is that your primary battery (601 indicates that it's primary) can only keep a 25% charge. To keep this quite simple for you, please attempt the following.
* Unplug your power cord.
1.) Start up your Laptop and hit the ESC key immediately.
2.) Press F2 to get into Systems Diagnostics.
3.) Select Battery Test. * Now, plug in the power cord.
4.) Start Battery Test.
The battery test will give you a STATUS. If you see the following;
- Calibrate: This means that your battery is functioning correctly but it is in need of calibration. Select the automatic calibration option.
- Weak: From here, please get a new battery to ensure that your getting adequate power supply to your laptop for use.
- Replace: Replace the battery.
- No Battery: If there is, indeed, a battery inserted. Remove it, check for dust/dirt and wipe it clear. Insert the battery and see if it works now.
- Unknown: Try to download all available updates from HP Support Assistant.
Feb 09, 2013 | HP Pavilion ze2000 Notebook
My battery does not appear to be charging. The Icon shows it at 24% or below and then the little light, that shows me that power is going into my computer, is very slowly pulsating
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. To to do this is to compare your laptop voltage & amp requirements (written on a sticker on the bottom of the laptop) with the voltage & amp ratings of the power adapter.
Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amps of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery does not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing.
In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Apr 11, 2011 | Gateway MC7321u Notebook
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
Taskbar power management
You need to calibrate your battery. Go to your BIOS then look for battery calibration then RUN the calibration process.
Check if the problem stills occurs.
Thanks. Cheers!
Apr 20, 2010 | Sony VAIO VGN-FW170J/H Laptop
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
I got a virus, knocked out internet and disk defragmenter
No virus program is 100% able to get rid of viruses. Some viruses are easily removed and able to be resolved, but others are not. You may need to do a reimage of your operating system. Save all data and make sure that once you have reimaged and reconfigured your OS, you do a virus scan on your data to make sure that remnants of the virus did not transfer to your files.
Nov 28, 2009 | Advent 4211c Notebook
The new battery will not calibrate
do you know for a fact that its the right battery? if you dont then its most likely not and i would recommend going to batteries-plus.
Aug 24, 2009 | Compaq Evo Notebook N400c
Wii Controls configured strangely
i,d suggest re-calibrating the Controllers And The Sensor Bar.
Theres a reset/reconfigure switch for The Controllers, Under The Batteries.
Also try moving the Sensor Bar, to the Left, or on top of set et,c.
May 29, 2008 | Nintendo Wii Console
Averatec 3200 Notebook Logo
74 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
