You have bypassed the Power On switch, by using a jumper wire to turn the Soft Power On, to see if it is the Power On switch that is bad? If the Power On switch is bad, (behind the power on button), you can replace it with any Momentary Contact switch. The Power On switch is a momentary contact switch. It's a spring loaded switch, so that when you let go of the power on button, the circuit made is broken.You have bypassed the Power On switch, by using a jumper wire to turn the Soft Power On, to see if it is the Power On switch that is bad? If the Power On switch is bad, (behind the power on button), you can replace it with any Momentary Contact switch. The Power On switch is a momentary contact switch. It's a spring loaded switch, so that when you let go of the power on button, the circuit made is broken.
You can't post conmments that contain an email address.
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Computer Post / Beep codes
The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working
POST troubleshooting steps.
then this issue is not a NO POST but is an power related issue see document ... For users who are more comfortable working with the inside of their computer.
