Question about Electrolux Central Vacuum
Electrolux Hi-light Hi, my hoover is making a weird knocking noise and emitting a burning smell. Took the lid off and the belt *seems* okay, but still makes the noise and the smell....
  • 55 Answers
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Posted on Feb 19, 2008
  • lloaulgur Jul 30, 2011
    Tried all that, burnt smell is gone, knocking sound is not as loud, but still there. I'ld like to try and fix it myself, what next? Or am I dealing with something bigger?
    President:
  • 1,673 Answers
Depending on the motor, either the motor fan broke or the motor has gone bad.
Posted on Feb 16, 2008
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Burning smell
Something may be keeping the brush roll from spinning freely which may have caused the belt to break.
Jan 02, 2014 | Electrolux Central Vacuum
I love my floor mate which I bought last year. Now it is making a funny sound and has a weird burning smell. I was told to take it to a repair shop but before spending the money I want to find out if this...
It may be the belt. Sometime the motor spins but the belt is not spinning with it. This causes the belt to heat-up and burn/melt. The burned rubber maybe what you're smelling and sometime make funny noise and hard to push the vacuum.
Oct 08, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Electrolux cylinder vacuum No suction and loud noise and smell of buring rubber
rollers are probably stuck the belt is burning check for restrictions in you hoses as well as in the vacuum as well if nothing else works a repairman
Jul 13, 2012 | Vacuums
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
The brush roller stops turning and I can smell the belt burning, then it will catch and start working normal. I looked under the plate to check the belts and they looked okay and no hang ups of string or...
better to replace both belts the smaller one is stretched out thats whyits slipping ,be sure to clean the old rubber off the motor shaft before replacing the belts.it will cause the new belts to run unevevly and go bad before their time
Aug 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My hoover elite rewind is making a louder noise and I can smell something burning when I use it. I have replaced the belt but this did not help.
the smell is either the motor or the belt, if motor hope it is under warranty, if belt make sure brush roll spins freely and replace belt, if brush roll not spin freely replace it first
Aug 27, 2009 | Hoover U5507900 Elite Rewind Bagless...
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
397 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
