Question about Ovens
Microwave Combi not working
My ED8525S-SBD microwave/grill/oven never gave me any trouble within the last twelve months since purchase. I plugged it in this morning and on the digital panel G-1 appeared and none of the buttons work.Could you help?
Left it plugged in for about 2 hours and it's OK now!
Posted on Feb 16, 2008
Microwave combi oven
Putting any metal object inside any Microwave is a problem, a large metal object destroys a part called the Klystron tube (the part that makes the microwaves), the energy from the tube is reflected back and burns out the Klystron tube. The part is most likely more than the oven is worth when you throw in labor to install it.
Sep 08, 2016 | Neff Ovens
Hi my Bosch Quantam speed microwave keeps tripping the electric when the oven is used. The grill and microwave settings both work fine. Any clues. ??
Yes, sounds like your oven element may be faulty and needs testing/replacing etc. However microwaves are best left to the qualified engineers. When you remove the cover, certain parts inside the microwave may still have live current present even with the plug disconnected and could cause serious injury or even electrocution!!
Oct 25, 2014 | Ovens
Siemens HB86E560B/01 microwave oven.oven working ok.when selecting wattage for microwave it cutts out after approx.30 secs. higher the wattage selection the sooner it cutts off. is there an overload heat...
Please have your power rating checked on the outlet and also if possible measure the mains voltage on the outlet . If low this can trip the microwave as it runs short of current/voltage.
Also make sure the plug is tight on the socket. Choose a lower wattage and see if the microwave works a longer time. If so the microwave must be checked within for a faulty capacitor, magnetron , wave guide or transformer.
Clean the oven , check the connections within and try once again before we can infer.
Aug 19, 2011 | Ovens
Conbi microwave oven and grill grill and oven working microwave not warming up light on and turn table working as normal
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 05, 2011 | Ovens
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
Does a moffat oven need a 30amp cooker socket or is it ok on a 13amp plug
Unless your talking about one of those tiny, table top ovens, dont use a 13 amp socket / connection.
An electric oven must be connected via a 30 amp SUPPLY - the socket is just the connector at the end of the cable that runs from the fuse / breaker board. A 30 amp supply will use a much thicker cable capable of handing the higher currents.
Whilst a very basic oven may draw less than 13 amps current when operating in some modes, most will draw well in excess of this depending on what facilities they have, e.g. bake and grill at the same time, or maybe a combi-oven - one that can bake and microwave at the same time.
Oct 03, 2009 | Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Delonghi microvave replacement bulb, microwave only 6 months old
I got a Delongi Mic form argos too ,model ED8525S-SBD, sounds like a similar problem to what happened to it last year. Issue is that the bulb explodes (mainly due to the very strong spring on the door I think) leaving filament lieing on the metal chassis, hence the trip switch in your fuse box trips.
Didn't manage to find a replacement bulb but at least if you remove the old bits then it will get the machine back up and running and stop the trip tripping!
Take off the top by removing the 4or 5 screws around the outer edge at the back. The bulb sits directly behind the front panel inside its own metal chassis. There is a diamond shaped black plastic flange which the 2 power wires feed onto. 2 metal lugs hold this inside the chassis. straighten the lugs and the bulb holder pulls out. Even with the bulb removed I think there was a blown fuse and I had a further issue with the turntable not turning(this feeds off the same circuit as the bulb). So maybe Argos were right - the machine only cost £80 at the end of the day!
Jan 31, 2009 | DeLonghi Ovens
Ovens Logo
160 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
