Vb.net2005 flexGrid Hi, I'm using vb.net2005.. How to use Flexgrid to Bind datas from Database.. And Hoe it will Edit ,Delete And Add New Records to database through Flexgrid..
  • Gavas Feb 15, 2008
    good
  • aliyall Mar 26, 2008
    i m not able for finding flex grid in vb.net2005
Borrow
Posted on Oct 27, 2008
  • 62 Answers
Http://blogger007007.blogspot.com
Here you can get download links for 18 GB of engineering and programming books. Just do a search of "visual basic" or "2005".
Posted on Feb 16, 2008
Send data from flexgrid to crystal report
Clearly specify the problem? What exactly are you trying to do?
Either one way of sending data would be
You can transfer the data from the flexgrid to a database table.
Then while calling the report you can call the data from the database.
Oct 15, 2009 | Computers & Internet
Retrieving acess data which is password protected thru VB
You will need to use a connection string. But - before you can configure the string correctly, I'd need to know how the data is stored (Access, SQL, ODBC, etc). You can find examples online. Just know that you are looking for "Connection String." Here's two examples:
1. For MS Access (Jet files):
' Set up the connection string.
m_strConn = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & strDestDBPath & ";" & _
"Jet OLEDB:Engine Type=5" ' NOTE: Use Type=5 for Jet 4.x.
2. For SQL database:
g_strADOConn = "Provider=SQLOLEDB;" & _
"Data Source=SERVER_NAME;" & _
"Initial Catalog=DATABASE_NAME;" & _
"User ID=mssql_userid;" & _
"Password=mssql_password;"
Apr 22, 2009 | Microsoft Visual Basic 6.0 for PC
Flexgrid with textbox
The arrow key will place you into the cell of your choice. In code you can determine the cell you are in by using the "Col" and "Row" properties. Here's a snippet for you:
Private Sub MSFlexGrid1_RowColChange()
Dim intCol As Integer
Dim intRow As Integer
intCol = MSFlexGrid1.Col
intRow = MSFlexGrid1.Row
Text1.Text = CStr(intCol) & " ; " & CStr(intRow)
End Sub
Mar 29, 2009 | Microsoft Visual Basic 6.0 for PC
I can't add data in the database using vb
The database can be any like oracle.
Two type of connection u can make.
One of such connection is ADODB
The code is like
Dim ors As ADODB.Recordset
Dim oconn As Connection
Dim Qry as String
dim Qry1 as string
Set ors = New ADODB.Recordset
Set oconn = New ADODB.Connection
Chk_selectall.Visible = False
oconn.Open "Provider=MSDAORA.1;" & "user id = " & Username & _
";password = " & Password & ";data source = " & Conn_string _
& ";Persist Security Info=True"
Qry = "insert into table1 values (100,'we')"
oconn.execute "Qry"
If u select any data then u ve to use
Qry1 = "select * from table1"
ors.open "Qry1",oconn
do until ors.EOF
msgbox ors(0) & "," & ors(1)
ors.movenext;
loop
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
VB With MC9090S
If you are willing to use VB.NET, then it will be easy. You would need the Symbol EMDK. With that and VS2008 (Express should be fine as well), you only need few coding steps:
1) Add reference to dlls
Symbol.dll and Symbol.Barcode.Dll
2) Finder a scanner
s = Symbol.Barcode.Device.AvailableDevices.First()
3) make a reader
r = New Symbol.Barcode.Reader(s)
4) add data
d = New Symbol.Barcode.ReaderData(1, 1024)
5) enable laser
r.Actions.Enable()
6) enable reading
r.Actions.Read(nrd)
7) add handler
AddHandler r.ReadNotify, AddressOf r_ReadNotify
8) read data in event
msgbox(d.Text)
That is all there is too it. Good day.
Jan 22, 2009 | Symbol MC9090 Barcode Scanner
How to link database to vb 6.0
make sure that you have ODBC drivers that match the database you want to get data from. Often there is security involved and the correct ODBC driver will prompt you for security information to get at the desired data and handle the necessary protocols to exchange data
Jan 07, 2009 | Computers & Internet
How to add columns(Vertical) only in Msflexgrid from database table using VB.
you have to open your current project in VB then go to "add references" (its somewhere in the menu bar) then go find microsoft acess and add it as a reference. then go to object browser and you'll find all the functions you need to interface between your project in VB and MS Access.
good luck !!!
Dec 30, 2008 | Computers & Internet
Edit unbound msflxgrid rows save changes in database
unbound FlexGrids do not directly accept data entry, but can accept data through the FlexGrid's KeyPress event or via a Textbox
For more detail see
http://www.pbdr.com/vbtips/gen/Article-UsingFlexGrids%282%29.htm
Dec 12, 2008 | Microsoft Windows XP Professional
Code for find the Ms access database size using visual basic
The way to get the database size is to point to the directory that the database is do a DIR statement with an output to a file as in DIR payroll.mdb>dbsize.txt and then read from the text file, the first field of the second line being the name (which you really don't need) then the size value of the database.
To import the text files using VB 8 use
'Imports System.Data.OleDb Dim conn As New OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0;Data Source=d:\path\filename.mdb") Dim cmd As New OleDbCommand("SELECT * INTO [import] FROM [Text;Database=d:\path;Hdr=No].[dbsize.txt]", conn) conn.Open() cmd.ExecuteNonQuery() conn.Close()
Nov 10, 2008 | Microsoft Office Standard for PC
Computers & Internet Logo
151 people viewed this question
Alun Cox
David Payne
David Payne
