Question about ASUS SiS Chipset CUSI-FX Motherboard
Up-date processor. I've changed my processor(celeron 400mhz) to pentium III (1ghz).I check jumpers to set in jumper free mode to the motherboard.So ,in the bios i don't have the chance to fix manually the frequency of the new processor.What do you suggest to do ? thank's a lot. francesco
  • 749 Answers
You only forgot to reset the CMOS on the motherboard, that's why.
In everytime you change the processor you also need to reset the CMOS to erase the processor settings...
Goodluck... Fixya me
Posted on Feb 15, 2008
  • ASUS Master
  • 13,433 Answers
Check the manual for jumper settings on the cpu frontsidebus frequency. Also find out your cpus fsb or frontside bus speed and match it with the motherboards jumpers if possible.
How to find out details of the processor?
Pentium III 1ghz - download cpuz www.google.com cpuz download
it will tell you more details of the cpu. If you post here a image of the cpuz screen or all the details it shows you can I tell you the correct fsb speed.
Then you need to find your motherboards manual and the part about those jumpers. and set them correctly.
Imperial gl ve 20020930 SPECS
TriGem (Company) Imperial GLVE (Model)
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07813&lc=en#N779
http://www.trigem.co.kr/tgservice/econsult/faqProduct04.asp?cls=0&Page=&ID=4237&C1=1&C2=68&C3=359&C_N=IMPERIAL-GLVE
Hmmm, I'm at a stalemate.
Looking at the specs for the motherboard chipset;
The Northbridge and Southbridge chip,
Intel 845GV
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Supports CPU's with a 400MegaHertz Front Side Bus, or a
533MHz FSB.
Naturally I can't get a clear picture of those jumpers, but they look to be 3-pin.
If we are to assume that the jumper pins set the CPU FSB support, from 400MHz to 533MHz, then the jumper cap is moved from either
Pins 1 and 2, to Pins 2 and 3; on J2 jumper;
Or Pins 2 and 3, to Pins 1 and 2.
I know !O_O!
Sort of a guessing game, as to where the jumper cap goes to what pins, for 400MHz FSB support, or 533MHz FSB support.
Do you have any idea of what the FSB is for the old CPU (Processor), that was in the motherboard? (Or is)
Let's say 400MHz.
You now know if the CPU you are wanting to use, needs 533MHz Front Side Bus support, you need to move the jumper cap to the opposite pins.
What happens if it's wrong? Nothing. processor just won't work.
Change the jumper cap back.
(NOT plugged into power when you do. Also FOLLOW Anti-Static Precautions)
Yes. I'm 'out there on a limb'
I am assuming after looking at the TriGem support page, for the Imperial GLVE motherboard, that the J2 jumper is used to change the FSB support for the Processor.
It MAY be that J2 has Nothing to do with CPU Support.
It may be that there is no jumper for changing CPU FSB support.
(Cleared that right up, huh? Geez!)
For additional questions please post in a Comment.
Regards,
joecoolvette
[J1 = FDD. Floppy Disk Drive
J2 = CPU FSB jumper
J3 = CMOS Setup
J4 = CMOS,
IMHO ]
Feb 19, 2013 | Computers & Internet
Is there a cpu upgrade for an hp pavilion 6835 with a motherboard 115561 cognac 20000731
The fastest Pentium 3 that will work in your board is a Intel Pentium III 1GHz chip. Here is a link to the specs:
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201000%20-%20RB80526PY001256%20%28BX80526F1000256%29.html
You could also get a Intel Celeron 1.1 GHz but it only has half the level 2 cache size so it's actually a bit slower than the Pentium III 1GHz chip.
Here's a link to celeron specs:
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20%28BX80526F1100128%29.html
May 23, 2012 | Powerleap PL-NEO/T Celeron, 1.4 GHz...
Currently i am using desktop computer celeron 1.7 Ghz which i am thinking to replaced by a P4(2.8 or 3.06) processor on the same motherboard. Apparently there is a voltage difference between 2...
If you motherboard will accept the P4 speed you want, you will NOT need to change anything. The board will automatically adjust the voltage when it sense the new cpu. I do recommend you upgrade your power supply that will support the voltage requirement. Most time when vendors build a pc with a low voltage cpu they usually use low voltage power supplies.
Check your motherboard specs, inparticular the voltage requirments and processor that are compatiable with your model board.
Good Luck.
C2Solutions
Jan 22, 2011 | Foxconn 661FX7MF-S Motherboard
What cpu can the motherboard 661M03-G support?
Vendor Type FSB Frequence
Intel Pentium Northwood 400MHz 2.0, 2.5GHz
Intel Pentium Northwood 533MHz 2.4-3.06GHz
Intel Pentium Northwood 800MHz 2.4-3.0GHz
Intel Pentium Prescott 800MHz 2.8GHz
Intel Celeron Northwood 400MHz 2.0-2.4GHz
Intel Willamette 400MHz 1.8GHz
Intel
Jan 30, 2010 | Foxconn 661M03-G-6EL Motherboard
I do not set FSB 533,change jumpers JP1A1 and JP1B1 is not effect
1.Do you have the jumper for JP1A1 on pins 2 and 3?
2.Do you have the jumper for JP1B1 on pins 1 and 2?
On that 6 pin jumper block, JP1A1 is on the left side. The side closer to where your mouse and keyboard ports are, (I/O area)
JP1B1 is on the right side, closer to the ram slots.
Pin 1 for both the JP1A1 and the JP1B1 are at the bottom. (Close to the AGP expansion slot)
Both of these jumper blocks have to be set in the 133M setting.
(133MHz. Intel Pentium 4 processors are Quad Pumped.
133MHz X 4 = approximately 533MHz)
PROBLEM is, (Not 'shouting'), that the EliteGroup P4VMM2 motherboard, will only support a Pentium 4 processor with a Maximum FSB of 400MHz.
1.Download page from EliteGroup Support for the motherboard manual, of the P4VMM2,
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=190&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
2.http://www.dooyoo.co.uk/motherboard/elitegroup-p4vmm2/details/
Sep 03, 2009 | EliteGroup P4VMM2 Motherboard
I want to upgrade my hpdv1000 pentium M processor whats the maximum upgrade allowed for this? i have upgraded it to 2gb ram from 512mb and 250gb hd from 60gb and its doin fine.
You should be able to upgrade the CPU, since it seems that the DV1000's motherboard uses a socket CPU design. But, obviously, HP would rather have you choose the CPU that you want from the beginning and stick with it.
The first thing to do is to check HP website to see what other configurations were/are sold for your model. If they sell it with faster CPUs then you can upgrade to one of them...
PLEASE NOTE:
In order for a particular processor to be compatible with a particular laptop:
(1) the processor must be physically compatible with the laptop socket, in your case I thing you have a Soket 479 processor
(2) the laptop chipset must support the processor.
(3) the chipset front side bus speed must match the processor front side bus speed, in your case 400Mhz.
(4) the laptop BIOS must support the processor.
So I listed here processors with FSB at 400Mhz, I gues that DV1000 as a 855GM Motherboard that supports only 400Mhz with Socket 479
Pentium M
Banias
Pentium M 1.3 1300 1024 400
Pentium M 1.4 1400 1024 400
Pentium M 1.5 1500 1024 400
Pentium M 1.6 1600 1024 400
Pentium M 1.7 1700 1024 400
Dothan
Pentium M 710 1400 2048 400
Pentium M 715 1500 2048 400
Pentium M 725 1600 2048 400
Pentium M 735 1700 2048 400
Pentium M 745 1800 2048 400
Pentium M 755 2000 2048 400
Pentium M 765 2100 2048 400
Celeron M
Banias-512
Celeron M 310 1200 512 400
Celeron M 320 1300 512 400
Celeron M 330 1400 512 400
Celeron M 340 1500 512 400
Dothan-512
Celeron 205 1200 512 400
Dothan-1024
Celeron M 350 1300 1024 400
Celeron M 360 1400 1024 400
Celeron M 370 1500 1024 400
Celeron M 380 1600 1024 400
Celeron M 390 1700 1024 400
Best Regards
Jun 23, 2009 | HP Pavilion dv1000 Notebook
SOYO's SY-P4VTP with 3GHz Pentium 4 Processor does not bootup.
check the rams and if they are ok
try to reset the bios settings from the motherboard jumper settings. like clear CMOS jumper will be there.
Apr 17, 2009 | Soyo (SY-P4VTP) Motherboard
New procesor not work
you might check the jumper for processor settings, maybe the jumper is not set to celeron? if it is working using the intel pentium check the specification of the mother board if you can use the celeron processor.
Mar 15, 2009 | Computers & Internet
My motherboard wont work on Pentium processor.
change cpu suply capastors with new one's and check jumper setting
Nov 25, 2008 | Computers & Internet
ASUS SiS Chipset CUSI-FX Motherboard Logo
118 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
