Question about Hotpoint Aquarius WMA56 Front Load Washer
Wma54 Not a problem really but what are the four buttons for at the top (wash m-c was in the house when I bought it recently). Quite a new machine. I think one is Time Saver, one is Extra rinse. What are the other two please? Actually the machine is a WMA54 not a WMA 56 but your dropdown at the bottom doesn't show that.
There are 5 buttons on my machine time saver, rince hold,extra rince,reduce creases and mini load.mine is wma54 also
Posted on Oct 14, 2008
I have a wma54 there are five butttons at the top
1. Time saver
2. Extra rinse
3. Rinse hold
4. Reduce creases
5. Mini load
in this order
Posted on Jul 30, 2008
    Sergeant:
  • 236 Answers
Will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Posted on Feb 16, 2008
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
Where is the filter on the hotpoint wma54 washing machine?
Remove lower rear cover of washer, locate and remove large black hose fastened to drum, inside you will find the filter.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WMA54 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Where is the filter on wma54 hotpoint washing machine
It is in the pipe which runs from drum to pump at the drum end.
Dec 15, 2008 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Washing machine WMA54 Hotpoint sticks on prewash
I realised that the washer was not filling properly with water!  So I pulled it out from the wall and noticed the cold water fill pipe had been squashed and had a kink in it so not enough water was getting through.  I remedied this by pulling the pipes through the under sink cupboard and securing them with gaffer tape,  Hey presto the machine now works again!  Hooray :D
Oct 06, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
I hate washing machines
check the suspension system. I am not familiar with this particular achine, but front loaders in general must have the straps put back on the tub when moved. if the unit recieved and hard drops or bumps it could have ruined/damaged the suspension causing it rock out of control. The suspension could be springs/ and or shocks, like a car
Dec 01, 2007 | Washing Machines
Hotpoint wma54 washing machine
sorry but not the job i would recommend to anyone not done or watched it done before its about the most difficult job to do on any machine, even though in my 20 years experience this is the easiest machine to do a drum bearing change on, most of the machine has to be stripped down, removing all the front panel / timer panel / door seal and drum front / drifting out the old bearings fitting the new ones and rebuilding the machine, not counting testing for and rectifying any damage the drum has done to the rest of the machine and surrounding parts, good luck if you attempt it, sorry
Sep 24, 2007 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
365 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
