Question about Saeco Incanto Classic Espresso Machine
Saeco incanto classic
I tied to make descaling according the instruction, but descaling continuously running without stoping and emptied all water tank without any warning. I can not reset by switching off and taking out power cord. When switch on machine again, it continue to make descaaling process. Is there any solution to reset machine ?
  • 1 more comment
  • Anonymous Apr 11, 2008
    i'm french and I also have the same problem...
  • Anonymous May 23, 2009
    I have a Saeco Incanto type SUP 021Y, after discaling no ignition of the whole green leds on the front panel in order to acknowledge the ending of the discalling. After many emptying water tank , no change.
    I check the low level magnet in the tank it was OK, I change the flowmeter, for a new one .Restart, new emptying the water, nothing new still the same . How can I escape from the discalling program, or how to reset the program
    Jean
  • Anonymous Mar 30, 2014
    My machine a saeco went off when we had a power surge due to a thunder storm. WHen I turn it on I get the message restart to solve problem however when I restart it the problem continues
I had the same problem, but running through water again again didn't help. After filling about four times, I concluded it was due to the magnetic switch that measures water level not kicking in at the right time (this is mentioned in other threads); I took the water tank off and placed a small magnet near the presumed location of the magneftic switch (adjacent to the the magnetic float in the water tank) and the unit immediately finished rinsing
Posted on Sep 20, 2008
Fille the water tank and let it continue. It will stop before the next tank runs out
Posted on Apr 04, 2008
I have a Saeco Incanto Classic. There is hardly any water coming through the coffee dispenser even if I only use the preground doser without inserting coffee. While the little water comes out it makes a...
Sounds like the the shower screen under the red o-ring in the brew group needs to be cleaned, you can remove the screen and clean or you can purchase some espresso machine soap puro caff or puly caff, and run it through the brew group using the preground method the clean out coffee oils.
Aug 26, 2011 | Saeco Incanto Classic Espresso Machine
I have a saeco incanto classic I have tried to descale 2 times and the red light will not go off, is there a reset buttton?
Hi
In order for the light to go off, the machine has to stop pumping on its own, both in the descale and the rinse mode. If you stop it before its done it will still be in the descale mode.
Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
May 04, 2010 | Saeco Incanto Classic Espresso Machine
English manual for a saeco sup 021 - decalcifying
You can download it from this link:
http://www.gaggiaparts.com/user/Incanto%20Classic%20MANUAL%20USA[1].pdf
Nov 14, 2009 | Saeco Incanto Classic Espresso Machine
How do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Oct 26, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Rondo RS SBS
if you open the steam knob, will there comes some water?
Aug 05, 2008 | Saeco Incanto Classic Espresso Machine
Saeco incanto deluxe
Try descaling it manually- by adding the descaler into the tank, letting the machine warm up and then open the water spout to fill one cup at a time. wait 15min. in between. Also clean brew group and grinder.
Jun 10, 2008 | Saeco Incanto Classic Espresso Machine
Saeco incanto
Do you get water?- If so, could be steam valve blockage somewhere and or steam boiler issue. Descale the machine first to see if this remedies the blockage.
May 08, 2008 | Saeco Incanto Classic Espresso Machine
Saeco incanto sup 021yr
did you ever descaled the machine not with vinegar but with real descaler normally that does the trick 1 part water 1 part descaler not vinegar put it in water cointainer start machine open side valve for a few second close it leave it in there for 15 minute repeat untill empty rinse very good with clean water that stuff is very corrosif cheers
Jan 23, 2008 | Saeco Incanto Classic Espresso Machine
SAECO SAECO INCANTO DE LUXE
descaling it with special produit not vinegar 1 part descaler 1 part water put in water container start machine open water valve for few second leave it for 15 minute repeat untill empty rinse very good cheers
Jan 21, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
620 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
