Question about Durabrand HT-3915 System
DURABRAND SA51AR have 6 points of connection, red and white, only have one white and one red socket in the television how do I connect it?
  • moto guzzi Feb 20, 2008
    the tv has not got stereo outputs so the six out puts from the surround system can only be plugged into the DVD direct and this only has two connections.
I too had this problem, but rest assured it is possible to sort out. Your TV should have a red & white socket on the front as well as the back. The other leads can then be plugged in to the DVD player.
Red & white in to the front of the TV.
Red & white in to the backof the TV.
Red & white in to the backof the DVD player.
I did this on my set up and it works a treat.
Posted on Aug 20, 2008
    Problem Solver:
  • 6 Answers
Based on your description, your Television has stereo outputs. Multiple channels may be "encoded" into those outputs, but your home theater system would need to interpret these encoded channels through one of its pairs of inputs.
I would try plugging the 5A51AR's Right/Left (Red/White) "Side Speaker" inputs into the TV's stereo outputs and see if the unit provides output to all speakers. There may be a switch on the unit labeled "Surround-Decode" or similar which needs to be set for this type of operation.
Posted on Feb 16, 2008
I have a 14" Konka
Hello
Look close to the input sockets, for which they are marked for. They may be for audio out from the TV. Red will be Right and White will be Left. It is meant for taking audio out from that TV, which in turn can be fed to any other external audio equipments, like amplifier or so. As there is no yello colured sockets in it, this TV is not meant for any other external inputs to be fed in. OK.
Jun 25, 2011 | Televison & Video
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
Hook up to dvd player
There are more than two methods of hooking up the DVD player.
1) Get a 5pin component cable with Red, Green & Blue pins. Connect the DVD Player's RGB out pins to the TV's RGB in socket. This will take care of the picture. Then for sound you will need the secondbobhifi_4.jpg set of Red & White cable. Connect the Red & White pins to the DVD players audio out socket (Red for right channel and White for Left channel ). The other end of the cable you can connect to the Red & White socket next to the RGB socket where you have connected the Video. Play a DVD and scroll through the inputs slowly. You will see the picture appear on one of your selections.
Mar 10, 2011 | Daewoo DP42SM 42 in. HD-Ready Plasma...
I am hooking this unit up to a fairly new TV. and I have plugged in the AV cables to the TV from the DVD unit, though I only have the red green and blue cables and tyhere appears to be 6 slots, and I get...
If you have only connected red green and blue (component) plugs, you will have no audio as these 3 plugs are all for video and all are required or you will get a black and white picture.
You currently have 3 spare slots/sockets. You need to connect another RCA type audio cable (2 plugs - red and white) from the left and right audio out sockets on the DVD player to the left and right audio in sockets on the TV. Do not disconnect any of the red, green and blue plugs to use for the audio connection!
Red is normally right and white is left, but it doesn't matter which round you connect them as long as you connect right to right and left to left. The yellow socket is for composite video so make sure you don't connect either of the audio cables to this socket or you will get mono sound.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | JVC TH-C30 System
Will an RCA Digital Convertor work on Durabrands model #1304.?.
Hello chlpepr2,
Yes it should work, connect the RCA video out (yellow connector DTV Converter) to the RCA video in (yellow connector TV set). Then connect the RCA Audio out (Red-Right White-Left DTV converter) to the RCA audio in (Red-Right White-Left TV set).
Then setup your converter box according to the manufacture's instructions.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 20, 2009 | Televison & Video
Durabrand
i have the same problem i canot connect the surround sound to my ps3 does anyone have any ideas on how to fix this problem
Jun 02, 2008 | Audio Players & Recorders
Same prob i also have the same problem my dvd is connected via scart to my tv i have nothing on my tv to connect the system to i have red and white on my dvd and also video so will this system work
i have just bought a DURABRAND SA51AR home theatre system, to go with my DURABRAND 2127N tv. and DURABRAND CG5660-M freeview set top box. i have connected all my output leads obviously the speaker ones. but my input i have only one red yellow white jack on my tv and three sets of red and white jack leads with home theatre system. cant get no sound no matter how many times iv swapped the input leads ... any idea s whats going wrong :oS :(
Apr 30, 2008 | Durabrand HT-3915 System
Connecting Durabrand SA51AR to computer
Each "red and white" represent a stereo pair (Right and Left respectively. What type of connectors are on the SA51AR? I will guess TS (tip sleeve) or Phono for the sake of this answer.
It sounds as if the PC's outputs are stereo TRS (tip, ring sleeve) 1/8" female connectors, which is normal. TRS connectors carry both the Left and Right signals whereas Phono and TS only carry one signal each.
Radio Shack has converters which will allow you to plug a "red and white" connector in one end (either TS or Phono) and will provide a TRS output on the other which will plug into your PC's sound outputs. That way, the Red/White pair for "Side Speakers" (front L/R) can plug into the one grey jack and the Rear (rear L/R) can plug into the black-jack, etc.
Feb 07, 2008 | Audio Players & Recorders
Connecting durabrand SA51AR
COnnect to the CD/MP3 audio pair.
Dec 28, 2007 | Durabrand STS92 System
not very helpful i have the exact same problem with no audio or video connection in my tv just 1 white and 1 red in my dvd player so is there some sort of adaptor you sell that can fix this problem? thanks
Dec 27, 2007 | Durabrand HT-3915 System
Durabrand HT-3915 System Logo
264 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
