Question about LG WM-2277HW Front Load Washer
Intellowasher WD-12126RD MY WASHING MACHINE WONT RINSE OR SPIN
  • donovanp1 Nov 24, 2008
    washes then stop doesn;t go to rinse or any other sicle
  • 66 Answers
It is coputer box in the washer. if it work on all other cycles. and stop on rinse. it need a new computer box . and in not hard to change.
Posted on Feb 16, 2008
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
I have an LG washer dryer (model 12126rd) and it has just cme up with either UE or VE on the frint LCD panel. What does ths mean? Thanks!!!
UE means imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Resolution: Move the washing around inside the washing machine to create a more even distribution of weight
Oct 25, 2009 | LG WD-12126RD Front Load Washer / Dryer
Only spin dry available?????
Yes, turn on the machine, push the button for spin to select the speed and then press start.
Apr 26, 2008 | LG WD-12126RD Front Load Washer / Dryer
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
210 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
