Question about Nikon Super Coolscan 5000 ED Film Scanner
Coolscan 5000 with SF210
We installed a Super Coolscan 5000 ED and SF210 feeder to a P4 PC with plenty of memory, CPU speed etc. Every slide we scan generates a picture on screen that is way too dark and we have to turn the brightness up to 85% approx before we get a half decent view. We're talking to Nikon but not getting very far and wonder if perhaps the kit is faulty. The kit itself is new from Nikon distributor and we've had it for about a week. The software is way too complicated at the moment to know all the tweaks etc but even on default settings we get a rubbish picture. We get the same with the single slide holder fitted. We also are unable to use auto scan, the software returns us to the desktop and we get messages saying that there is a hardware error. We desperately need this to work as we have a total of 50,000 slides to scan, not all right now, but we have to send a fair number off to the publishers and we have a tight deadline.
Apart from shipping it back to Nikon does anyone have any ideas.
Thanks
Lloyd
  • 3 Answers
I'm sure all is well but if you have not tried VUescan or Silverfast as opposed to Nikons Util you should.
Posted on Nov 14, 2008
2 Suggested Answers
  • 5 Answers
SOURCE: Coolscan 5000 with SF210
u can change your usb cabli and install all the drivers to scanner and set to setting to scan software and adjust the image our choice
Posted on Mar 18, 2008
The scanner is only 24mm wide and 36 mm long, so rotate you slide by 90 degs.
May 03, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
Nikon Coolscan 5000 ED not scanning
Have you tried resetting the scanner itself?
Jul 09, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Tip
Nikon Super Coolscan Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 4000?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Tip
Nikon SF-210 Slide Feeder Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan?
Try this solution:
I hope that helps.
on Apr 09, 2010 | Nikon Sf-210 Slider Feeder For 5000ed...
Trying to install Nikon Super Coolscan 5000 ED, for some reason the installation disc doesn't have the LS-5000 ED driver software...? I am running Win Vista. Any ideas?
I do not believe Nikon made drivers specifically for Vista, but you can use the solution here to make your own driver "inf" file and install some that will work anyway. Please read this and carefully follow the directions. If you are using 32 bit, use the 32 bit drivers. If 64 bit, then 64 bit drivers, when creating the new inf.
Bryan Clark
DVD Your Memories
Slide Scanning Specialists
Nov 16, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Need driver for Nikon super coolscan LS 5000 ED
Go to Nikon's official website, then search for support. You'll be able to download all the drivers and Nikon Scan software. Hope this helps.
Jan 15, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Tip
Fix that Jamming Slide in your Nikon CoolScan 5000ED / SF-210 Slide Feeder
I balked when someone whispered this tip to me; the thought of putting foreign objects into my Nikon CoolScan 5000ED slide scanner with its SF-210 slide feeder seemed asking for trouble.
After about a thousand slides worth of experience, and many batches that seemed to jam every other slide, I gave it a try and boy did it do the trick.
The SF-210 slide feeder works flawlessly with newer, thicker, plastic slide mounts, but if you are archiving and digitizing older, cardboard slides like I am then here's what wasn't printed in the CoolScan user's manual:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below.
I hope that helps.
on Dec 04, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Nikon CoolScan 5000 ED not connecting to PC
We de-installed the software and re-installed it.
Dec 31, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
I do have three nikon 5000ed scanners running for 18 hours a day in my company. I encountered this problem a lot. Nikon service center charged me for changing a power supply unit in the past: that was not the fault in my oppinion; It could be either a software or hardware fault.
I dedicated a page on my website for fixing and performing maintainance on the Nikon 5000ED scanners.
This information and inside pictures of the Nikon 500ED scanner could be found at
http://www.scancare.nl/scanner.html
Mar 16, 2008 | Office Equipment & Supplies
Scanning monochrome negatives on Coolscan 5000ED
Your killing yourself how big are you going to print this!!! Are you using Vuescan or silverfast for scanning or Nikons util? Stay away from Nikons utility! 2x sample is plenty and turn off ICE for monochrome (it makes a mess of things) but 16 bit yes until you print then go down to 8 after you resize for final print.
Morphoto.ca
Mar 05, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
Open Questions:
See all Nikon Super Coolscan 5000 ED Film Scanner Questions
Nikon Super Coolscan 5000 ED Film Scanner Logo
251 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
