Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Router i forgot what wear to go on the internet to change the setting on my router
  • sarah29uk4 Feb 18, 2008
    thankyou fix the problem manage to get router on but still need to know how to lock the router up so know elea can get on it
    Brigadier General:
  • 3,614 Answers
Try the address 192.168.2.1 / or 192.168.2.0
Posted on Feb 15, 2008
I forgot my router password so i want to know what can i do to reset it
You will have to reset the router to factory defaults
BEWARE - this means you will lose all the router settings and will have to set them up again including the ADSL settings which your internet provider should be able to help you with. Then when you setup wi fi security all the computers will need the encryption key and sddi broadcast name changed to match
To reset to default settings, turn off the device first. Hold the Reset button and then turn on the device; wait for 5-8 seconds and then release the button. Reset device's configuration to factory default.
http://setuprouter.com/router/trendchip/hg520/manual-1089.pdf
(the default username/password is admin/admin)
you will need a direct connection ethernet cable between a computer and the router as the wi fi will be not set up after the reset.
Sep 28, 2016 | Huawei HG520 ADSL Wifi Router
I bought a Wii and would like to set up my wireless internet to it, but I can't. I stupidly removed the sticker on my router and forgot my password. Can anyone help me?
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 19, 2011 | 2wire (1000-400108-001) Router
I forgot my access code to my d-link internet. How can I change the code?
You can just do a reset on the router. There is a reset on the back. Use a tooth pick or pen to push and hold for about 15 seconds. Doing this will reset all your setting. You will need to setup your router again.
Jan 08, 2011 | D-Link DIR-615 Wireless Router
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Trying to hook another laptop on to the wireless internet but forgot the passphrase/ key code
if its the default then should be on your router... id you have changed it on the back/side of you router there should be a reset button (very small) need paperclip push it in and should reset to defaults. or from the pc attached type in 192.168.0.1in internet explorer to access set up page and change password
Feb 02, 2010 | Dynex Wireless-G USB 2.0 Network Adapter
I have forgot my wireless password
hey what you can do is you can reset the entire router... by using the reset button on your belkin router... Or else you can also access the router by using the following IP address in the internet exlorer...
try 192.168.1.1 or 192.168.1.0 & then go to the wep settings & reset the router or change the password for the router...
Mar 26, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Forgot Wireless router password?
the easiest way is to reset the router and start from scratch
Mar 21, 2009 | NetGear WGR614 Wireless Router
I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
Nov 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Setting passwords on dell truemobile wireless router
Hello, The default address for the dell truemobile 1184 is 192.168.2.1 If you have changed it and forgot, unplug the router (elec) for 5 seconds. This will reset it to default. The default SSID is "wireless". If a user ID and/or password is asked for enter "admin". Here you can change settings, enable broadcast, change SSID, enable WEP or WPA. Hope this helps.
Mar 16, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
15 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
