Question about Intuit QuickBooks Pro 2003 Single User Retail - Ships SAME business day. S&H $5.95+ (028287006546)
Quickbooks 2003 won't run in vista
Yes i facing the same problem, installing QB in Vista, during installation first it tells me it's unable to open the fonts folders, so i tell it to cancel and it continues installing the rest of the program well up to the end. when i try to run it it gives the a RUNTIME ERROR MESSAGE. whats wrong
  • 5 more comments
  • mdragano Jan 05, 2009
    Same problem here. During installation, I get a warning that it can't open the fonts folders, after I click OK it continues installing the rest of the program. When I go to run, I get the RUNTIME ERROR MESSAGE - abnormal termination. Help!
  • kdtool Jan 06, 2009
    I just got a new Dell computer which has Windows Vista. I have Quickbooks Pro 2001 and the 2003 upgrade that I want to use. My backup of my company information is on Quickbooks Pro 2003. If I buy a newer version of Quickbooks Pro that is compatible with Vista, can I restore my company information in the newer version?
    Thank you for your time and help-if you can!
    KD Tool
  • celababy Feb 05, 2009
    I have the same problem, installing QB 2003 contractor edition in Vista 64, during installation first it tells me it's unable to open the fonts folders, so i tell it to cancel and it continues installing the rest of the program well up to the end. when i try to run it it gives the a RUNTIME ERROR MESSAGE.
  • armani13 Feb 16, 2009
    I have the same problem trying to run quickbooks2003 on vista only i had already tried running it as an admin and it still just open and shuts right back down... :( Can anyone help????..
  • Anonymous Feb 27, 2009
    run time error after install. Is there a Patch?
  • Anonymous Mar 19, 2009
    The solution worked fantastic. However it wont let me process invoices or receive payments etc. What do I do?
  • Anonymous Apr 14, 2009
    The right click on the desktop icon solution really works. Thank you!!
Worked Great!! Thanks.
Posted on Jan 22, 2009
Computer crashed - installed new hard drive and quick books pro9 2001 - opens but when clicking on its closes says programme closing
QuickBooks from 2001 will probably have serious compatibility issues unless your operating system is from 2001 as well.
If you have a new operating system (Windows Vista onwards) you may be able to install and run QB in compatibility mode. I have it running on Vista Professional.
Right click on the executable and select Run in Compatibility Mode and then select Windows XP from the options.
If you do not have the option to run in Compatibility Mode, you will need to update QuickBooks, or your OS or best of all, both.
If you have no luck running in CM, uninstall the program, reboot and then install the program from the disc by using the same compatibility technique. You will need to disable autorun if the program tries to install itself when you put the disc in the drive
Oct 05, 2014 | Computers & Internet
Opening QuickBooks Pro 2009
Sounds like your re-installation of QB did not update your registry files properly.
I would suggest:
1) make a backup of your data
2) uninstalling QB
3) delete the QB installation folder entirely
4) re-install QB
5) restore your data
If this doesn't work, I can provide "remote desktop support" to try a more comprehensive approach.
Jan 27, 2010 | Intuit QuickBooks Pro Edition 2009 Full...
Will WIndows upgrade affect QB Basic Ed 2003?
I cant seem to find the manual for OS support. If windows XP is supported, the program works the same. For Vista and Win7 don't know really. Always when you're in doubt, makes the backup default.
Jul 29, 2009 | Intuit QuickBooks Basic Edition 2003...
Error message Library not registered
I got the message "Line 25: Library not registered" after uninstalling QuickBooks Pro 2009 and trying to run my old version of QB Pro 2006.
(I had installed 2009 version to upgrade my QB2006 Pro version but got into problems with multicurrency support not being supported in the Canadian QB Pro 2009.)
Fix is VERY easy and I think it applies to anyone trying to run an older version of QB Pro after uninstalling a newer version.
Fix is to find the file "reboot.bat" located in the program files associated with the older QB version.
In my case it was found in "C:/Program Files\Intuit\QuickBooks Pro" folder.
Just double click on the file to run it. This file tells the system where parts of the QB program are located including the DLL libraries it needs. After running this file you should be able to run your old QB version OK. No rebooting necessary.
May 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Jan 21, 2009 | Intuit QuickBooks Premier: Accountant...
Error message when installing QuickBooks 2005 to new 64 bit compu
Hello, I found this on another web site intuit community. I tried this and it works. A couple of people said they had to run this each time they signed on but i have not had to.
Welcome to the community forums. One thing that I notice with your error log is that all the missing files are .dll files. I would suggest running Reboot.bat which re-registers the QuickBooks .dll files.
Do a search on your computer for reboot.bat (there is a seperate one for each version) and run the reboot.bat that corresponds to version of QuickBooks you are having a problem with.
It worked for me and I am so happy because as stated QB not longer supports 2005.
Lorene renie1954@yahoo.com
Le me know how it goes for you
Jan 06, 2009 | Intuit QuickBooks: Pro 2005 for PC
Reinstalling 2002 pro
Sorry to tell you that you will need to upgrade. Quickbooks is only compatable with Vista in 2008 and up. Quckbooks is not doing anything to resolve older issues.
Dec 17, 2008 | Intuit QuickBooks Pro 2002 (260102) for PC
Is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
Feb 14, 2008 | Intuit QuickBooks Pro 2003 Single User...
Computers & Internet Logo
5,021 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
