Wont Record Will play back . But wont record. Manual says erasure prevention tab broken. This is not correct, as tapes have been recorded on same video player prior. When a tape is put in it starts to play without pushing play.
  • Rockydudes Feb 19, 2008
    Thank you it works out the mechanism has failed. So will be sending back to seller. Thanks again
  • 4,102 Answers
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
Posted on Feb 15, 2008
  • paul proctor Feb 20, 2008
    Hi sorry i havent been online for couple of days but the mechanism that failed was that the recording prevention switch that had failed this is probably no good to you know as you sent it back to seller but you could have bypassed this mechanism allowing you to record again anyway hope you got sorted in the end
HOW DO I RECORD WITH A SONY SLV-N77 MANUAL DOES NOT HAVE ANY DIRECTIONS
Looks like a great brand with good features for the price.
  1. Connect Video & Audio Cables to a video signal source
  2. Connect Power Cable
  3. Turn on VCR.
  4. Insert a blank tape in the VCR.
  5. Note - A Broken Tab on the back of tape will prevent recording. This is called Write Protection.
  6. Cover the tab hole if you want to record over old video.
  7. Press RECORD on the VCR remote control.
  8. After a minute, press Stop, then PLAY to see recording.
  9. Cheers
Aug 18, 2014 | Sony SLV-N750 VHS/S-VHS playback VCR
Buttons Play or Play&Record will not stay gown
There is a feature, in a cassette recorder, when a cassette is "locked" to prevent it from erasure or record, if you break out a little notch on the back of the cassette When this is done, you can't press the record button. Perhaps something connected to that feature is blocking your deck. If the back pice of plastic left of the hole, is gone, the cassette is "write protected".
Look inside to see the "pal" that is in the deck.
Or perhaps your deck has a relais that should hold the button down, but it does not get any power? 6f4f166c-a584-4d29-9da6-e149a704708f.jpg
Jan 16, 2014 | Audio Players & Recorders
I cannot get my RCA Boombox Model no.RCD150 to record. Is there a trick to recording?
No trick. Did you follow the manual's instructions? What DOES it do instead? Are the erasure-prevention tabs missing from the target tapes? See page 14.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RCD150-Boomboxes-manual/id/402ci674/t/2/
Jun 30, 2011 | RCA RCD150 Radio/Cassette/CD Boombox
Tape doesn't stay down, keeps popping back out of cassette, on my Sony CCD-TVR608. Any ideas?
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Aug 17, 2010 | Sony Handycam CCD-TRV608 Camcorder
Does not record, but plays back
One possibility is that the record sensor in the video that pushes on the back of a video tape where the tab that can be broken off to prevent recording on to the tape, is either bent out of shape or broken. They are often small switches easly replaced.
Dec 11, 2009 | Sony SLV-N88 VHS VCR
When i put a tape in it ejects it..then a tape with a slash appears on the screen
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
You can press play and pause, but then you can't press down rec. help.
Is the erasure prevention tab missing from a commercial or previously recorded cassette? It would leave a little (about 1/8" square) hole in the spine edge of the cassette shell. That tab is there to prevent accidental erasure by allowing a small sensor lever to drop in and mechanically disable the recording mechanism. Compare a commercial cassette with a brand new blank one. You can place a piece of adhesive tape on the casette to allow recording, but take care to NOT cover more than the first 1/8" of the opening if it is larger as the recorder also senses tape type by the length of the hole molded into the cassette.
Word to the wise - don't scrimp on the tape if the recording matters to you. Spend a bit extra for better tapes. Store the tapes 'played', avoid fast forwarding and rewinding unless you'll be playing them through to wrap the tape uniformly before storing it INSIDE its tape box. Read the other warnings that come with the media. No heat, moisture, dust, blah-blah.
Jul 08, 2009 | ION Audio TAPE2PC Single Cassette Deck
VCR ejects tape when I try to record using the timer facility
Simple. The Cassette's 'Prevent Erasure' tab is missing. Just cover with Scotch tape and reload. Now try recording.
Nov 29, 2008 | Televison & Video
Dictaphone indicates end of tape
The sensor that detects the tape movement is bad and will need to be replaced.
Nov 10, 2008 | Dictaphone 2741 Desktop Cassette Voice...
TAPE EJECTS WHEN I PUSH THE RECORD BUTTON
Simple solution.In all probability the Erasure prevention Tab on the cassette is broken. Just paste a Scotch tape on the broken Tab and try again.
Mar 18, 2007 | Akai VS-K338 VHS VCR
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
