Question about HTC PPC-6800 Smartphone
HTC power usb connector repair
My little plastic piece inside the USB connector is broken
need the connector replaced.. is that possble and how much will it cost
can i do my self, where do i get the part from and how much will be it in cost
  • santosh32 Feb 18, 2008
    AM IN LOS ANGELES CA, LET ME KNOW HOW MUCH WILL IT COST ? TO GET THE PART AND FROM WHERE?
    Master:
    Sergeant:
  • 462 Answers
Yes we can replace it, but it will involve soldering which u need to be good at...? else u will spoil ur board...? Where do u stay...?
Posted on Feb 15, 2008
  • Mohamed Ismail
    Mohamed Ismail Feb 18, 2008
    Are you going to solder it or are u going to a near by electronics mobile repair shop...?
    If u dont mind, i would request you to take it to a mobile repair shop and ask how much it will cost, because u may be lucky to get it fixed for a low price, instead of paying heavy for ordering it...!!
    Please give it a try, if not send me ur details of ur handset..!!!
    Thankyou
Turn off audible alarm when changing towers
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
God bless you
Jun 01, 2013 | HTC Cell Phones
USB port broken on old IBM Thinkpads
Marite,
Thanks for providing the pictures. You don't know how much that kind of input helps!
In looking at the pictures you've sent, the only way to repair this is to replace the connector. It can be fixed, however you need to be aware that the cost to obtain a part as old as this plus the labor involved will probably be much more than the unit is worth.
One thing that you might want to try is to buy a USB hub and plug it into the working port. A USB hub is a kind of extention cord that will give you several USB ports.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Nov 20, 2007 | Computers & Internet
The usb port is broken. It does not activate or power the interface. How Do would you go about having it repaired?
All USB ports have four leads attached. Tthe outside rails contain the positive and negative voltage of 5V and the two inside rails is the transmit and receive. I would take the interface apart and replace the USB connector. Maybe Radio Shack or another electronic shop would have the same USB connector. See:
http://69.84.140.50/content/Article.aspx?Type=L&ID=468
Jan 05, 2011 | M-Audio Fast Track Ultra 8R 8 x 8 USB 2.0...
Broken Hub
The plastic piece is kind of just a spacer - you could probably Crazy Glue it back in place (just a drop - even less). This might work if the contacts in that port are not messed up.
But you can get a new one for just a few bucks. See/get one here:
https://www.ebay.com/sch/i.html?_sop=15&_armrs=1&_dmd=1&LH_BIN=1&_ipg=100&_from=R40&_sacat=0&USB%2520Specification=USB%25202%252E0&_nkw=usb%202.0%20HUB&rt=nc&LH_PrefLoc=1&_trksid=p2045573.m1684
Or here:
https://www.google.com/search?client=firefox-b-1&ei=YaFgWoeYGoiksAWl1J2QBg&q=usb+2.0+HUB&oq=usb+2.0+HUB&gs_l=psy-ab.12..0l10.1395089.1395089.0.1396689.1.1.0.0.0.0.217.217.2-1.1.0....0...1c.2.64.psy-ab..0.1.216....0.zcpQSn0m82o
I would recommend that you buy a self-powered (one that you plug in to a wall outlet) USB hub, because sometimes USB ports on a computer do not have enough power themselves to power a non-powered hub.
Good luck.
Jan 18, 2018 | D-Link (DUB-H7) 7-Port USB Hub
The usb port is broken. How do i fix it?
you can get a USB connector on your local electronics store and replace the USB connector, but is better find a new case to your HD, is usualy easy to find a empty case on your Informatics store (OEM)
Jan 03, 2010 | Computers & Internet
Broken black piece inside usb port
This is usually going to be a part replacement problem. the black piece is part of the connectors. and backs up or guides the connectors. you can go to your local computer parts store such as frys, or an electronics parts house. and buy the connectors unless it is one that is attached to the motherboard in the back of the computer. if this is the case and you do not have enough usb ports, then you have to get an external usb hub. usually a powered hub is best.
Nov 12, 2009 | Computers & Internet
My MP3 USB is not recognized by my PC,
May be a bad USB cable. Check the connector on the end that plugs into the pc, something inside may be broken preventing the connection. Sometimes the flat plastic piece inside (white or black) breaks loose if you forced it into the usb port or felt resistance when inserting it. If it came with software, you may have to reload it especially if you are using Windows 98.
Mar 12, 2009 | Nextar MA168 (128 MB) MP3 Player
Broken USB connector
it depends if the port has come off with out damaging the board if its damaged the board its more harder to replace the port. sometimes you are luck and its just broken the slider as its tin base. and it can rip, but you cannot tell until its been opened and looked at.
Jul 03, 2017 | Logitech Harmony 676 LCD Remote Control
Front usb port of xbox looks broken, unit does nothing now
Simple. Just solved it with advice from this site. If you see any of the gold prongs touching the side (or possibly each other) then find a thing tool and try to hook the gold prongs so they point direct upwards. how bad they get bent doesnt matter, just get them all standing up and not touching the sides. you probably cant use the port again but atleast it turns on.
Oct 16, 2008 | Microsoft Xbox 360 Console
HTC PPC-6800 Smartphone Logo
381 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
