Question about Boss Riot 1500D Car Audio Amplifier
Help BOUGHT A RENEGADE AMP 4 CHANNEL WORKING FINE FOR THE PAST 4 MONTHS NOW ONE SIDE OF THE AMP IS DEAD WHAT CAN THIS BE CHECKED THE FUSES AND ALL SEEMS OK
    Habit-Forming:
  • 59 Answers
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Posted on Feb 15, 2008
Renegade 50 headlight fuse location
Hi, Scott for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Renegade, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Renegade 50 scooter headlight fuse location Google Search
Guide How To Check Your Fuse On Your Moped scooter madness motorbike...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Chinese Scooter Parts Diagrams
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 17, 2017 | Motorcycles
Where are the fuses for 2002 jeep liberty renegade window fuses?
POWER WINDOWS
ALL ARE DEAD.?????????
post symptoms first.
some have fuses some are CB, circuit breakers.(not fuses)
ok i looked, its not like other cars.
the window controler runs off Ignition switch pin 2 and 4
RUN and accessories
so that means ,if you blow that fuse, not only windows die (all)
but engine too and vast other things
why no tell all things that work on not
like, drives ok at night all lighting works ok.
but all windows dead.?
Jan 07, 2016 | Jeep Cars & Trucks
NAD 7030 just stopped working on one channel. The speaker will work if the mono button is pressed in. Could this be a fuse problem ?
most likely it will be poor soldering on the input side - the fact both speakers work in mono means the pre & main amps are working fine
Feb 27, 2015 | NAD Audio Players & Recorders
Ren 550 s amp does not have blown fuse but is not working
Chances are that you have internal problems with your amp, they have a 1 year warranty so I would check to see if you can get an RMA to get it fixed or replaced. They still sell this model, so chances are good you may be covered. It seems like these are mostly sold in Europe, Onlinecarstereo.com sells them as an authorized seller. To get the 1 year warranty you probably will need to have bought this from an authorized dealer. But try anyway.
http://www.renegadecaraudio.com/renegade_rens_amps.htm
Apr 02, 2013 | Renegade REN 550 S - 550W 2-Channel Car...
We have an old amplifier from back in the 80's and 90's. Its 500watts, the right channels (both main and sides) work fine and loud, but the left channels produce very low sound. I checked the fuse and its...
Have you checked the final transistors on that weak channel? They may look fine but may be weak. You can pull them and check them on your multimeter with the diode check and cross it with the data sheet for that transistor.
Mar 07, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Adcom GFA-7400 power amp; 1 dead channel (thermal protect LED on)
Hi...
I've contacted ADCOM before and they sent a pdf of the electricals
http://www.adcom.com/default.aspx
also try:
www.stereomanuals.com
Mar 30, 2010 | Adcom GFA-7400 5-Channel Amplifier
Kicker 550.3 amp will not power up
do u have the remote wire hooked up to the (rem) spot usally inbetween the pos and neg?
Mar 15, 2009 | Kicker ZR360 Car Audio Amplifier
American pro vs1403 lost one channel out of four
Have you moved all of the switches, controls and RCA jacks to make sure that the problem isn't a dirty contact?
Have you tried swapping the RCA signal cable from a working channel to confirm that it's not a signal problem?
Have you swapped a speaker from a working channel to the dead channel to confirm that it's not a speaker problem?
It's unusual that one channel goes dead and the rest work.
May 18, 2008 | American Pro VS1403 Car Audio Amplifier
Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Jan 27, 2008 | JVC RX-1028V Receiver
Kicker amp troubleshooting
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 01, 2007 | Car Audio & Video
Boss Riot 1500D Car Audio Amplifier Logo
142 people viewed this question
Top Boss Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
