Question about Baby Gear
Vehicle problem One of my wheel stud (rear right) is broken and i want to replace it. How can i fit it?
  • 50 Answers
You need to remove the broken stud from the hub and maby run a thread tap through
Posted on Feb 15, 2008
Do I have to remove the center nut to replace broken lug studs
the correct way is to remove the hub and use a press so yes the hub nut will have to come off
the studs are pressed in and it you use a hammer and drift to remove/replace the broken studs , you will damage the wheel bearings
Apr 03, 2016 | 2004 Infiniti QX56
How do I replace all five lug nuts on front driver side wheel?
They are pressed in from the backside of the wheel hub that the studs stick out from. And not like needing a heavy press- once you get the old studs driven out (usually works with a hammer or small mallet), you can easily draw the new studs right into a snug fit by using the lug nuts, the new ones you just bought along with the 5 new studs, available at most any parts store.
See it's not the lug nuts that are broken, those nuts tighten the tire to the hub by the lug nut studs that the tire fits over. It is the studs themselves that are breaking off. This is common enough that parts stores carry replacements. A chevy dealership might have just your size in stock, if you don't mind paying extra high dealership charges, but it might not be that much for these rather inexpensive items. In a lot of cases, the studs can be removed from the hub as it sits, but there are cases where the hub must be removed from the vehicle for stud replacement. You can eyeball it and pretty much tell if the studs can be removed easily, after you take the wheel (tire) off. For any work on the vehicle, don't rely on the jack. Use blocks or jack-stands always.
Oct 25, 2015 | 2000 GMC Jimmy
Jbl 75815 stud broke
First, it really depends on your car model. normally its easier to replace broken stud on the rear disk than the front if your car is a rear wheel drive. On the rear, the moment you remove your tires you only need to initiate impacts on the disk to loosen it and after removing the disk you can hammer the broken stud to dislodge it from its fitted hole then pressure fit the new one in place by hammering it in unless you have a machine that can do it. On the other hand, replacing broken stud on the front requires you more efforts as you need to detach other items like the disc plate cover, and if necessary dislodge the spindle assembly from the velocity joint to create space for the broken stud to be removed from its hole.
Aug 02, 2014 | JBL 2447H Driver
How to replace a rear wheel stud
remove the wheel
using a hammer and punch knock the broken stud out
fit the new stud from behind use over size nuts as spacers fit the stud nut and apply tension
using the hammer and punch from the rear on the head of the stud knock it in as you keep the tension on the stud nut
keep the process going until the stud is fully seated on the head of the stud
Jul 10, 2014 | 2005 Toyota Camry Solara
2001 altima replacing rear wheel stud
strip it down to your hub the hub holds the studs .it is a push pull fit .but an old nut on it.then hit the top of it .it when then push in.remove the nut. push in the new stud from the rear of the hub.put a larger nut on top of stud ,then your wheel nut to pull the stud into the hub.then remove the wheel nut .then refit the parts taken off.and fit your wheel.
Dec 30, 2013 | 2005 Chrysler PT Cruiser
2006 dodge caravan with rear draum brakes. Broken wheel stud on right rear wheel. Got the drum off, got the broken stud off. but i cant get the new stud in. not enough space to get the new stud in. Is...
Make sure all tires are chalked,put vehicle in neutral,turn drum till it has a clear spot to knock stud out,use hammer and wooden block,don't use metal punch,can cause burr on end of stud and not want to come out of hole.Both tires on back may need lifted in air to turn.
Jul 05, 2017 | 2006 Dodge Grand Caravan
I need instructions on how to get a broken rear wheel stud on a 2003 grand am.
Rear wheel drive? Remove the axle shaft by either removing the four bolts behind the brake drum, or remove the differential cover, push the axle shaft in and remove the C clip inside at the end of the shaft.Then drive the stud out with a hammer, hammer in the new one, replace the axle.
Front wheel drive? Remove the bearing cap , remove the Bearing nut(s). Remove the hub, replace the stud as outlined above.
Dec 29, 2011 | Chevrolet Vehicle Parts & Accessories
How do i get the rear hub off to replace the wheel studs
On some vehicles you may need to slightly pry the hub off. This can be done with a screw driver or the vehicle may have a lug wrench that came with the vehicle. If you are trying to replace the lug studs, then you will have to take the wheel off. Tap the broken stud out and replace it with the new one.
Nov 27, 2010 | Ford F-250 Cars & Trucks
Broken rear wheel stud on a 2005 ford focus zx4 se
  1. Step 1 Buy a new stud. Make sure you purchase the right size. If you're not sure what size to get, wait until you remove the stud and take it with you to the store.
  2. Step 2 Check the area of the spare tire in the trunk for the jack and the jack tools since you'll need to raise the car to replace the wheel stud on your Focus. Be sure to block the tire diagonal to the jack.
  3. Step 3 Use the jack to raise the Focus. Remove the wheel Take off the caliper and either hang it by a mechanics wire or lay it up so it doesn't dangle by the brake line. Remove the rotor. If you're working on back wheels, you have to remove the emergency brake clip first. You could have drum brakes in the rear. If they're drum brakes, remove the drum.
  4. Step 4 Hunt for an opening behind the hub that allows you to remove the stud. Line the stud up with the hole. You may have to take off the hub and put it in a vise if you can't drive it out the back.
  5. Step 5 Hit the stud with a mallet and drive it out the back of the hub. Push another stud into the opening. This is tough work, but you only need to push it far enough to thread on a wheel bolt.
  6. Step 6 Put on a wheel bolt and begin to tighten it. As you do, the stud starts to pull through. Add more bolts as necessary until you seat the stud. Check in the back of the hub. When the head is flush with the stud, you seated it.
  7. Step 7 Remove the extra bolts and reassemble the parts that you took off to replace the wheel stud on the Ford Focus. Put the wheel back on the vehicle and tighten down the wheel nuts.
Sep 25, 2009 | 2005 Ford Focus
Broke stud on front left side
Yes you can replace the broken wheel stud. The wheel studs are pressed into place, and a vise will work to press it out, and in. You will have to remove the wheel hub, and then use a deep well socket and a bolt or something smaller than the actual stud to remove it with a vise. To replace it, you will need to use the deep well socket on the thread side of the stud, and press the new one in with the vise.
I hope this helps you, and I wish you luck with your repair.
Apr 25, 2009 | 2003 Pontiac Sunfire
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
