Question about HP LaserJet 1320 Printer
Load Noises HI, I have a problem with this laserjet 1320 in work, I have been told that this has been happening from it was got. When the paper in tray 2 get down about half way the printer can't lift it an really load clicking noises come from the printer, but now it will do that at times when the tray is full and yesterday a squealing noise started when it was printing an it also starts and stops. Any advice would be most welcome Thanks Paddy
My HP Laser Jet Printer has the same problem. Now it only works by using the manual feed tray. Odd Noise always comes when I am trying to print. The light of paper jam is on when I am trying to use the main tray. But I can not find any jammed paper in it.
Thanks.
Posted on Feb 21, 2008
  • 89 Answers
This sounds like you may have a couple of different issues. It seems as if there was a paper tray issue and now some other gears may be broken or out of line.
The feed issues could be tested by trying to feed using the manual feed tray. It could be the feed rollers are worn and that is why it sitll worked when the tray was fun. As for the printer stoping and stating I would need more detail
Posted on Feb 18, 2008
  • 118 Answers
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Posted on Feb 16, 2008
Hp 1320 don't stop printing
my hp printer 1320 always prints two papers one of them is white.
what caused this problem?
Nov 02, 2012 | HP LaserJet 1320 Printer
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what...
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Sep 07, 2011 | HP LaserJet 1320 Printer
Hi I have a HP LaserJet 1320 Printer and when sending multiple documents it is pausing between them. I have to press the Green button to make them print, until the start of a new document when I have to...
Is the paper size set on the computer for the size of paper you are printing to?
Usually if you have to give a 'thumbs up' to the printer is because it is trying to print on an different size paper.
Aug 09, 2011 | HP LaserJet 1320 Printer
Red light blink on hp 1320
Hi there!A red light can be anything from toner to a paper jam to no paper!!Good Luck!
Oct 23, 2010 | HP LaserJet 1320 Printer
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Mar 25, 2010 | HP LaserJet 1320 Printer
After cleared paper jam, HP LaserJet 1320 prints blank pages
Yes you can replace the transfer roller, but check to make sure the roller is firmly seated into its holder and that the springs are contacting the metal shaft.
Good Luck
Nov 20, 2009 | HP LaserJet 1320 Printer
HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Oct 09, 2009 | HP LaserJet 1320 Printer
Hp 1320
I want the software of laser jet 1320 printer
May 19, 2008 | HP LaserJet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
622 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
