Question about LG KG800 Cellular Phone
Mobile troubleshooting my lgkg300 mobile sleep of my hand in water please help me
  • 47 Answers
Unfortunatly water damage is hard to fix take your battery and sim out and use a blowdryer to dry it and let stand for a day and try to turn it on hope fully it didnt sit in the water for long
Posted on Feb 16, 2008
Stays in sleep mode. How do i fix?
To help you troubleshoot the issue about unable to wake up the laptop from the sleep mode, please find the link given below and follow the instructions:
http://windows.microsoft.com/en-US/windows7/Open-the-Power-troubleshooter
If issue persists, please find one more troubleshooting link given below, which may help you to resolve the issue:
http://support.hp.com/us-en/document/c01853693
GuruAid.com
Apr 19, 2016 | Compaq Presario Cq60-615dx Laptop Lcd...
Sleep/hibernate mode
Hi, If the computer seem to wake from sleep mode for no reason? Some device settings can cause the computer to return from a power savings state when not expected. If the computer is using an optical mouse, changes in light can cause the computer to wake. Network activity can cause the network hardware to wake the computer, especially when the network is always on (like cable and DSL connections). High Definition Audio audio may also cause the computer to wake from sleep mode. Use the following steps to prevent the these hardware devices from waking the computer:
  1. Click Start c00847244.gif , and then right-click Computer .
  2. Select Properties , and then click Device Manager in the left panel of the window.
  3. Click the plus sign ( + ) next to the device that needs to be adjusted. If you are using an optical mouse, select Mice and other pointing devices . If the computer is using an "always-on" connection, click Network Adapters . To check the high definition audio, click Sound, video, and game controllers .
  4. Double-click the name of the device to open a Properties window.
  5. Click the Power Management tab, and remove the selection from Allow this device to wake the computer . Figure 6: Power management tab for a mouse c00851648.gif NOTE: If you prevent the mouse from being able to wake the comuter, wake the computer using the Sleep button on the keyboard or from the power button on the front of the computer.
  6. Click OK , close the windows that are open, and then restart the computer.
  7. Click Start c00847244.gif , and select the Sleep/Standby button to see the problem still exists: If the problem still exists, go to the next Step.
  8. Disconnect all non-essential connected devices (printers, scanners, USB drives).
  9. Restart the computer with only the original mouse, monitor, and keyboard connected. If this resolves the sleep/standby problem, one of the connected devices was causing the problem. Replace one device and test to see if the problem occurs again. Continue adding devices and testing until the you find the device that is causing the problem.
If you have already tried all the above steps, you can try the steps below: Many software components start up automatically and run without being seen. Most of these programs are not necessary to the work performed on a computer, but can interfere with sleep/standby mode. For troubleshooting purposes use the following steps to prevent programs from starting when Windows is first opened.
  1. Click Start c00847244.gif , and then type msconfig into the Search field and then press the Enter key.
  2. The System Configuration Utility appears. Click the General tab, select Selective startup , and then and remove the check from Load startup items . c00847247.png
  3. Click OK to accept the changes and restart the computer.
  4. After completing these steps, Windows opens using Selective Startup. A small reminder may appear when Windows restarts. Select Don't show this dialog again and click OK to prevent the reminder from re-appearing every time the computer is restarted.
NOTE: To undo the changes made in this process repeat the steps above and replace the checkmark next to Load startup items .
  • If disabling Load startup items did not resolve the suspend problem, go to the next step.
  • If disabling Load startup items resolved the suspend problem, enable one startup item and test to see if the problem occurs again. Continue enabling startup items, until you find the software task that is causing the problem. Remove or update problem software.
If the problem still exists, go to the next Step. Upgrading the BIOS and keyboard software If the sleep button on the keyboard still does not work, go to the HP Software and Driver Download page , enter your computer model number into the field provided, and install any keyboard and BIOS updates for Windows Vista. Should you require any further assistance regarding this issue or any other computer related issue in future please feel free to contact get back to us, we will be more than glad to assist you.
Regards
Malik Khan
Feb 01, 2008 | Microsoft Windows Vista Ultimate Edition
I have the adjustable bed, but have lost the remote control. Two #'s that I see are 17500249 & 062805.
ADJUSTABLE BED ACCESSORIES AND SERVICE
adjustablebedmart.com/accessoriesservices.html
REPLACEMENT HAND CONTROLS We have both hard wired and wireless remotehand controls. Does your hand control look like one of the two on the left?
Sleep Number Bed Replacement Parts ' Sleep Number
www.sleepnumber.com/sn/en/.../bed-replacement-parts
Select ComfortREPLACEMENT PARTS. Remote control. Most issues with your remote can be easily resolved by following certain troubleshooting steps. If your remote is ...
Jan 25, 2016 | Televison & Video
Water dispenser does not work
Good Afternoon Friend,
I understand that the water dispenser on your Frigidaire refrigerator does not work. First, I suggest changing your water filter, making sure that the filter is flush with the filter housing. Secondly, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try to get water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. If further troubleshooting is required, please leave me the model number of your refrigerator. Typically you can find this number inside the refrigerator on the right hand wall. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Disable Sleep Mode
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Bar+Code+Scanning/General+Purpose+Scanners/LS2208_US-EN
Mar 18, 2013 | Symbol LS2208
Should I hand-wash my sleeping bag?
Probably. I wash ours all the time. What is the material and filling? Down or feather bags are hard to wash and I like dry cleaning those.
For synthetic bags, load loosely in a top load washer or better yet use a front-load machine. The front loader tumbles the bag instead of using an agitator. Use minimum soap, and do an extra rinse. SPIN SLOWLY. You do not want the weight of the water to tear anything inside the bag. After it is done, then you can spin it faster because most of the water will be out. Then dry in the dryer. Some people say to put a couple of tennis balls in with it or an old shoe -- apparently to fluff it around a bit more.
Aug 05, 2012 | Camping, Backpacking & Hiking
Dear Sir, I have LGKG300 mobile phone i want to
Please log on to the offficial site of LG:
Click on : LG phones
Dec 01, 2010 | LG KG300 Cellular Phone
Code 93 saltwater system
Hi, Code 93 is telling you that the system is done running, did you mean to say it said 92? That code would be for too much salt. If indeed it is a Code 92 you are getting, give Intex a call, or email. I have found their website to be very helpful, they have a F&Q's area. Good luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Download Lg kg 300 mobile driver to run internet through mobile
i have lg kg 300 and want to connect internet on computer through my mobileso i need it's driver can u help me?
Aug 13, 2008 | GPS
LG KG300 cellular phone
i forgot my LG KG 300 phone pin code
can u tell ho w i solve the prob
Jan 31, 2008 | LG KG800 Cellular Phone
LG KG800 Cellular Phone Logo
23 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
