Question about Logitech QuickCam for Notebooks Pro Personal Web Camera
When i try to open my quick cam for notebooks delux version 10.0 it says there is a run time error
I have the windows vista home premium program. it was ok other then the picture was fuzzy, so i uninstalled and then reinstalled and now when i click on it to open it it says a run time error. please help. thank you linette martin email linettem@earthlink.net
  • angel23 Feb 16, 2008
    Yes it worked just fine, thank you very much for your help as i was getting no where. Linette
  • 19,396 Answers
Try re-installing the latest drivers for your operative system from Logitech website here: http://www.logitech.com/index.cfm/435/3055&cl=us,en
cheers
Posted on Feb 15, 2008
When I try downloading my picture from my camera to my pc it says it can't. It has just started this. It has always work until now. What could be the problem.
Looks like Picture It! Premium 10 is not compatible with windows 7, for more information check the windows 7 compatibility link.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?type=Software&s=Picture%20It%21%20Premium%2010
Windows 7 Compatibility Center
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
You can still install Picture It! Premium 10 on windows 7 in a compatibility mode.
Run the Program Compatibility Wizard 1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Mar 14, 2011 | Microsoft Picture It Premium 10 for PC
Does it work with windows 7?
That depends on which vesrion of windows 7 you have ?
The basic versions of windows 7 do not generally alow every program to be run that was designed for an earlier version of windows.
HOWEVER
I have found no problems running any application at all so far even if it was intended for an earlier version of windows.
The home premium version of win 7 is the lowest and may on rare occasion cough and spluter when running XP/vista apps.
In my tests sometimes the installation does fail but windows 7 then takes over and asks if I want to re-install using corrected setting.
If I let it do that then the installation has always worked.
Apr 20, 2010 | Nova Development Photo Explosion Deluxe...
WINDOWS VISTA LIVE SAFETY SCANNER
vista safety scanner is compatible with all version of vista OS. there are no issues about it.
Feb 17, 2010 | Microsoft Windows Vista Home Basic for PC
Windows vista home premium. Lost adobe reader and
When Windows Update stops working, the first thing I suspect is a virus. See if you can download and install Malwarebyte's Antimalware. Update the virus definitions and run a quick scan. If you are not able to do this, boot the computer into safe mode with networking and do it (tapping F8 while booting) Run a quick scan & delete anything it finds. Try WU again and see if it works.
Malwarebytes can be downloaded here:
http://dw.com.com/redir?edId=3&siteId=4&oId=1770-20_4-0&ontId=20_4&spi=94faea6144de2554b617b78c5e46df79&lop=link&tag=tdw_dltext&ltype=dl_dlnow&pid=11164457&mfgId=6290020&merId=6290020&pguid=C3uNrAoPjFsAACb50NIAAAAX&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-20_4-10804572.html%3Fspi%3D94faea6144de2554b617b78c5e46df79
If you were infected, run a full scan as well.
If WU still is not working and your computer is clean, try this
http://support.microsoft.com/kb/971058
Then go here and try installing Reader v8
http://get.adobe.com/reader/otherversions/
Feb 15, 2010 | HP Compaq nc6120 Notebook
Itunes & Quick Time won't open.Unknow error (-69)
You need to run iTunes as Administrator.
The default shortcut doesn't allow this so you will need to create a new shortcut.
Also make sure ther is no CD in your CD drive when starting.
Aug 02, 2009 | Microsoft Windows Vista Home Premium with...
My windows can't check for updates (windows vista home premium). it's showing error code 80244019
Press Win+R, type 'services.msc' and press Enter. Respond to the UAC prompt. Check that Background Intelligent Transfer Service is started and its startup type is 'Automatic.' (It can also be Automatic (Delayed Start).) If it is not started, right-click on it and select Start. Scroll down to Windows Update to make sure that it is started and it startup type is 'Automatic' or 'Automatic (Delayed Start).' If it is not started, right-click on it and select Start. If you had to start either service, try to run Windows Update again by clicking on Start -> All Programs -> Windows Update.
Apr 14, 2009 | Microsoft Windows? Vista Home Premium...
Cannot upgrade windows vista home premium from disc
Check the programs that vista says it can not update. They may be incompatible with Vista. You can find this out by running the Windows Vista upgrade advisor available for free at microsoft.com. If you really want Vista & can do without the offending programs you can uninstall them & then run the upgrade. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | Microsoft Windows Vista Home Premium with...
Error message when opening quick cam
You need to uninstall your camera
restart and then reinstall the cam.
This should help
Jan 11, 2009 | Logitech Webcam
Problems with hp2601tx
Your computer came with a restore cd I am sure, so you can get vista back later if you need.
Here is a tutorial made just for you. You will need to own an XP CD. pre-installed-windows-vista-computer/">http://www.howtogeek.com/howto/windows-vista/install-windows-xp-on-your-pre-installed-windows-vista-computer/
You can buy laptop coolers almost anywhere for $20 to $30. They will get hot. I try to keep my laptop on a flat open surface to allow maximum air flow. Setting it on you lap insulates it and it gets warm. Nothing out of the ordinary.
You may be able to download an updated driver from HP that will fix your web cam problem. There may also be another program running that is trying to manage the web cam also. Take a look at your running programs and close any that are related to the web cam and see if you error still occurs.
Apr 04, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Logitech QuickCam for Notebooks Pro Personal Web Camera Logo
48 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
