Constant static I have my monitors connected to a usb midi mixer (edirol by roland) through rca to 1/4 phone plugs and have a constant static noise with light beeping as soon as theyre on before any audio is playing. Even while playing sound at low levels i can hear the noise while at higher levels i cant even notice it. As of now i havent used them since because i am afraid of causing any damage. Is this a minor issue i should overlook or will it damage the monitors in the long run? If i could have any input on this matter I would be so appreciative- Thank you
  • Anonymous Dec 09, 2008
    I have the same problem. I think it is a minor issue. I just think it's very annoying!
  • 102 Answers
Well i would sugest that it is just a minor problem but depends how old your midi mixer is try updating that may solve problem
Posted on Feb 15, 2008
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Roland e09 read "midi error" when connected with
If you have the version 1 cable you need to download a driver. The details are at this link:http://www.cme-pro.com/en/news-detail.php?news_id=105
Nov 08, 2010 | Roland Juno-D
I'm having problem connecting my Casio Keyboard with my Edirol MIDI Interface, I can't get a connection and the lights on my interface will not go on. Please any suggestions will help.
You have to have the driver for the interface installed CORRECTELY. Make sure you followed directions as sometimes you have to have device p;lugged in while installing and sometime not.
Then you will need the user software in your machine to talk to the interface as well... The interface PROBABLY must be directely connected to your machine, not through a USB hub.
Nov 02, 2010 | Roland Edirol USB MIDI Interface (UM2)...
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
Notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Jan 18, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Edirol UA-25 not working on Mac OS X
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Nov 19, 2008 | Edirol UA-4FX External Sound System
145 people viewed this question
 Grubhead
Grubhead
