Question about Dell F3534 Touchpad
Dell xps M140 laptop touchpad
I like my touchpad to be really sensitive, so I set the sensitivity where I want it, but when I close the laptop and open it again, the sensitivity is changed so that I have to press harder to move the pointer and I'm tired of having to constantly change it back to the more sensitive setting. Any ideas?
  • Anonymous Jan 29, 2009
    I have a mix of issues, 1) the settings go back to default every time it is turned off. Some times i have to tap it 3-6 times to select or move the pointer from one field to another 2) when typing the text can move all over the page, like i am brushing the touch pad with my hand when typing, cause me to delete and retype many thing in the correct place
  • Anonymous Mar 25, 2009
    Same problem: you close or hibernate the machine; when it restarts the touchpad is basically unresponsive. It appears to work intermittantly, then goes back to unresponsive.
    Trial & error reveals that if one presses 'really' hard on the pad, it works, but all 'tap' response gone.
    Upon reboot, all is normal.
    On mine, this behavior just started...was okay before.
Hmm I don't have this problem... but i do need some new touchpad buttons and can't find any :|
Posted on May 17, 2008
I have the same problem and it sucks. Not sure how to fix it.
Posted on May 04, 2008
  • kuma63 Dec 30, 2010
    I had touch pad problems so i bought a mouse and turned the touch pad off. problem solved
How to adjust touchpad sensitivity on dell inspiron 1525
Open Control Panel, Mouse, I don't know your OS?, OR, in the Tray Notification Area, open the Touchpad software Icon, maybe synaptics touchpad, settings, sensitivity Take a look at the Dell forum: http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=cmu&k=adjust+touchpad+sensitivity&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False
Feb 08, 2013 | Computers & Internet
Dell xps m1330 vista home curser jumps when typing
Have you loaded your touchpad drivers? The only time I've ever seen than happen is when the touchpad drivers aren't loaded. The touch is extra sensitive if your palm(s) just barely touch the pad.
By loading the touchpad drivers, you should be all set
Oct 27, 2012 | Dell XPS M1330 Notebook
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
Cannot find synaptic touch pad sensitivity control using dell studio 64 bit windows 7
have you tried running as Administrator, and/or compatibility mode for XP SP 2, is digital driver signing, disabled at every bootup via F8? Is you .net framework up to date?
Feb 17, 2010 | Dell Inspiron XPS M140 Notebook
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
Touchpad too sensitive
You should find the settings are either under the mouse settings, or under the touchpad's own controls, in Control Panel.
Jul 01, 2009 | Dell Inspiron 1525 Laptop Flamingo Pink
My Dell M140 has no touch pad settings/tab
there is no setting for the touchpad. it is set at the factory with hardware components under the touchpad.
Nov 13, 2008 | Dell F3534 Touchpad
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Computers & Internet Logo
865 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
