Question about Refrigerators
Refrigerators problem problem with my refrigerator and freezer is dont give me any water or ice .it just stop ,but light on door is "on' when you swithching from water to Ice and getting brigther and then shuts off. still making ice and everything else work fine. if you please can give me any idea what going , which part I need order to fix this thank you
    Scholar:
  • 90 Answers
What model and make is this unit? It could still be in the door switch as it may think the door is still open. The switch that changes from ice to water could still be at fault. On some there is a cutoff switch up under the lip of the opening where you get ice and water which can be turned off to avoid children from holding the switch down and emptying out the ice or running water all over. Make sure it is working correctly and not in the off or partially off position......
Posted on Feb 15, 2008
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Turn on water light on outside of door
Can be faulty control panel causing these.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 24, 2012 | Maytag Refrigerators
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
The freezer door is not sealing properly and seems to be off the track.
the spare seals are available,if the seals are not sealing,then may be its got worn out/ over stretched so it has to be replaced.
These will help.
Thanks,.
Dec 22, 2012 | LG LFX25971ST Bottom Freezer French Door...
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
Dear Help 'Desk, I have a Samsung silver nano fridge/freezer. I've broken one of the removable door shelves in the freezer. Can you suggest a suitable (preferably clear) glue to repair the
Fevi-quick stick fast glue will be useful.It will take few minutes to hold the broken parts.Dont put overload of food stuff on the rejoined tray.But it will hold the basic load.
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Why is green light flashing
Its indication of overfreezed fridge or freezer unit.Or any door not getting closed properly.
These will help.
Thanks,.
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
