Question about Brother MFC 210C All-In-One InkJet Printer
Mfc210c printer cant clean its self
As above brings up error cannot print because it cant clean
  • 832 Answers
The ink absorber box is fed up with waist (cleaning) ink. You need a new ink absorber box which can be bought from a service püartner near your home (see www.brother.com and click your country)
Posted on Feb 15, 2008
Scanning not possible. See chapter about problems and ordinary maintenance in users guide
(Ther error displayed in Norwegian is: "skanning umulig" on my MFC-620CN ). After passing more than 6400 copies this printer is programmed to display this error message as the ink absorber box might be full. If you think it might not be quite full yet, you can simple change the PURGE COUNT from 6400+ to zero by following the steps in the service manual above. Then it will work as normal again. You can get the service manual your self free at http://pcmediks.blogspot.no/2010/09/brother-dcp-110c-mfc620cn-mfc210c.html
Mar 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
My mfc210c displays an unable to clean message, what do i do
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 18, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean,check manual
LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or
Oct 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
Still not printing - HELP!
Not sure whether this applies to your exact siuation but may be worth a try:
Brother MFCs self clean excessively and when they've done a set number of self-cleans, they refuse to print and give an error message which leads you (unsuccessfully) to the Troubleshooting section.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Sep 15, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error messaage "unable to clean" on a MFC210c
There should be a number with the error, if it's 46, you need a new ink flushing box. You won't be able to fax until you clear the error.
Jul 01, 2009 | Brother MFC 210C All-In-One InkJet Printer
MFC210C wont print yell or blue only blk &mag. HELP!
Pull the cartridges out and them turn it off and then turn it back on then try placing them back in...Because the cartridges work on suckion.
May 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc210c printer driver
I believe your brother printer uses one driver for fax/scan and another driver for printing. It might seem like you haven't installed the printer driver, only the fax/scan driver. You should find the driver file and the instruction on this brother.com page:
PS: the driver linked to above is for os 10.4. You might want to search for a different version if you have a newer/older OS.
If the link doesn't work, search for the driver from brother.com's site and download and install the driver by following their 12 points instruction. Good luck!
Dec 11, 2008 | Apple PowerBook G4 Mac Notebook
Borther mfc210c black ink not printing even after cleaning
if your brother machine is within warranty, give the tech support a call. if not,replace the black cartridge with a new one. it may be a defective cartridge that you have or if you are using refilled cartridges, it will also give the same problem
Nov 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
181 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
