Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Changing the blade on The Turbo A5 Pet clippers
I just got my new clippers and I am trying to put the blade on.  The instructions say to turn the motor on and insert blade on tongue fully then snap blade into place.  I don't know what the "tongue" is, and I can't get the blade to snap in place, and with the motor running I'm afraid I'm going to break it.
  • 4 more comments
  • bossyv Feb 15, 2008
    I'm looking at the box and it says Oster Turbo A5 Two Speed and the number at the top is 78005-314.  On the clipper itself there is a tiny number PN111038-030 and then another number 5-314B
    Do I communicate with you by clicking on the add comment button?
    WHAT!!!!!!!!!!!!!!!  I don't understand what you told me to do!  Before I came on this web site I had "Googled" everything on a Oster clipper and it never showed a "Tongue" or how to replace the blade.  I found every kind of replacement part to order, but not a picture of the "tongue" on the clipper.  Help!!!!!!!
    What is image search mode?
    I think I know what the "tongue is", but I am  "shredding" it up trying to put the blade on it with the motor running, and I still can't get the blade to "snap into place",
    OH MY GOSH!  Your are a genius!!!!!!!!  I never knew how to work that feature of Google.  I found a wonderful picture and instructions.  I now can use my clippers!!!!  I would never have figured this out with out you wonderful help!!!!!!!!  THANK YOU!!!!!!!!!!!!!!
    bossyv
    Master:
    Sergeant:
  • 462 Answers
Hello
Posted on Feb 15, 2008
  • 4 more comments
  • Mohamed Ismail
    Mohamed Ismail Feb 15, 2008
    Can u tell me the model no and the make...!!! It will help me solve ur problem...!!!
  • Mohamed Ismail
    Yes u communicate with me by clicking by the add a comment button..!!! I am going through your specs..!!!
    Thankyou
  • Mohamed Ismail
    To know the different parts or locate them, just put ur search on google along with the part name in the Image search mode then u will findout what is tongue in ur shaver...!!!
    Thankyou
  • Mohamed Ismail
    First when u go to google search site...!!! On top u will find something as Image, this means for all the search u give, only picture will be shown..!!! Do u understand now...?
    Thankyou
  • Mohamed Ismail
    Try to snap without the motor running, that should be safe as u will not only break ur clip, also u will be safe from getting cuts on ur finger..!!!
    Thankyou
  • Mohamed Ismail
    With pleasure bossyv.....!!!
    I am always there for any help...!!! Nice chatting with you..!!! Please refer me to ur friends too...!!! :)
    Have a nice day...!!!
How do I change the blade?
There is a small button at the bottom edge of the blade, push it in and at the same time push the blade teeth away from the clipper. The blade will hinge away from the clipper, you then lift the blade up off the tongue. When fitting another blade pop it onto the tongue, turn the clipper on and snap the blade shut.
Mar 31, 2015 | Oster Turbo A5 2-speed Dog Pet Clipper...
Is there a tool to get the Motor housing back into the A5 clipper case.
No special tool you need to make sure you have removed the gear wheel in the gearbox, locate the armature inside the motor frame first then slide the motor housing complete with the armature into the body of the clipper sometimes you may need to twist a little to get it in. I have put a link below so you can see the parts I have mentioned.
http://www.angliaclipperservices.com/Clipper_Parts/Oster/A5_Golden
Dec 31, 2014 | Oster Turbo A5 2-Speed Horse Clippers W/10...
Conair clippers manual
RTM. Read the manual. You can find a manual in .pdf format if you use Google and put in the make and model and manual and you should get results.
Aug 23, 2014 | ConairPro Canine FX Turbo-Groom II Pet...
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Jun 21, 2014 | Oster Turbo A5 2-speed Dog Pet Clipper...
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Can't put on a new blade
start the clippers then slide the blade onto the tongue of the hinge assembly , now push the blade into the clipper don't be afraid sometimes they can be tight from new,
Just make sure the two screws either side of the hinge are tight.
Aug 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
315 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
