Question about Mitsubishi WS-65615 65" TV
Medallion ws-65615 The timer light keeps flashiing and i cant get tv to turn on? I tried holding menu button for ten seconds but that didnt work? Plz helpp me!
    Champion:
  • 206 Answers
When this type of Mitsubishi flases the timer light constantly it means The DM board has some power but has not booted up. This problem is becoming more common in these sets, There are Four capacitors that fail in the DM board but if your soldering skill are weak you may want to take this somewhere to get it fixed
Posted on Feb 15, 2008
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Push power button and timer button lights for a few seconds and then tv turns off model is Ws 55859
When it shuts down go to the set and press the menu and the Device/Input button both in together and hold for 6 seconds then count the two digit blink code from the power indicator. it will blink a two digit code which repeats several times.
Jul 23, 2011 | Mitsubishi WS-55859 55" Rear Projection...
I have a Mitsubishi Medallion HDTV Integrated 1080 WS-65615 and the speakers wont work. I've tried the the whole speaker/audio stuff but it wont let me select tv speakers.... help please!
hummm if i may suggest something... do you have net command enabled this would disable the speaker selection giving control of audio to other devices.
Oct 15, 2010 | Mitsubishi WS-65613 65" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Green light of "hell"
Try reinitializing the set press menu 8970
Oct 13, 2009 | Mitsubishi WS-65615 65" TV
Mitsubishi ws-65615 tv flashing timer light. tv
ONLY 1 of 2 things can cause this problem----First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD TECH
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
Apr 27, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Tv problem
hold the menu button down for 10 seconds tv should power up you will have to turn off front panel buttons on menu hope this helps
john
Jan 24, 2008 | Mitsubishi WS-65615 65" TV
Mitsubishi WS-65615 65" TV Logo
241 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
